Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree9Likes
Thread: Guidance engine swap in 1999 2.8D nissan safari
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    Default Guidance engine swap in 1999 2.8D nissan safari
    Currently using factory fitted RD28ETI diesel . either to replace it with td42t or tb45e . how much hassle in converting to petrol . what are the engine prices like . how to find these engines .
    best regards
    Site Banned Follow
    vyrus's Avatar
    Nov 2009
    25
    1,611
    1uzfe is what i'd recommend.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    on PW you will only hear the toyota engine names being thrown around..
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Smile
    True - Because Toyota is holding 80% market share in Afghanistan in terms of new & 2nd hand Imports. And engines are Transported ( read smuggled ) from across. & local yards in Pakistan are full of those. Ask for any other stuff and price is like Gold will shy out.
    fadijaved's Avatar
    Jun 2010
    275
    to phr aap bta deen na koe aur...
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    why not ask for a TB45 - Im sure you can find it.. it will be a proper swap job for your vehicle, or a little RB30 - it will work nice in your application,
    btw is it 3 or 5 dr?
    These engines would be slightly pricey than your parchoon ki dukaan toyota engines. but are tough as nails.
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    3 drs swb . converting to petrol is bigger swap job
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    TD42 would be available in karachi - but may I ask why? is the RD28 not upto oomph
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    its a efi version cant find some sensors plus i have a issue with head .
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    I know what version it is..
    I had a customer with that once, it had hot start issues - the reason was a sticking timing advance piston solenoid in the pump - usual RD28TE problem, nissan have a cure for it. Its an updated part no for the solenoid - and takes 2 hours to remove and install.
    That fault makes the engine feel like it has no compression and is incredibly hard to start, as it rotates the cam plate in the pump to extreme advance when hot, with the pump on start (max fuel) position the situation only gets worse, The person who owned this certain SUV that I fixed had got estimates of head overhaul etc, while infact that little part from solved it completely. Instant start, good power, no smoke and cool running.
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    where is it on pump physically . i guess that can be the cause . what should i do . remove it . how to replace it . how to set pumps timing adjustment . any way i can test it .
    i guess needle lift sensor is going crazy . can that be cause .
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    on the side where the usual spring loaded timing advance or cold start unit is. In your case its electric. the pump operates just like the 1KZ pump. a needle lift sensor dumping fuel into the main pressure head and the camplate pushing the plunger, the amount of fuel is metered by the spill sleeve.
    The correct way to test timing on this engine is an AB light as you cannot isolate the advance to set the timing dead spot on.
  13. #13
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    thank you
    what if i replace the solenoid advancer with conventional advancer with spring
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    it wont work - as the ECU controls the advance, removing that will result in ECU going to limp mode.
  15. #15
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    does disconnecting needle lift sensor on the first noozle effects advance solenoid function . any way i can test if timing solenoid is defective . i am 90% that u have diagnosed it right .should i look for one in scrap yard ? .
    thank you
  16. #16
    wodeln's Avatar
    Aug 2011
    Adda shaiwala
    16
    on PW you will only hear the toyota engine names being thrown around..Guidance engine swap in 1999 2.8D nissan safari - cartoons6Guidance engine swap in 1999 2.8D nissan safari - cartoons7Guidance engine swap in 1999 2.8D nissan safari - cartoons8
    Great words!Lots of toyota!!
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by funduro View Post
    thank you
    no it wont affect - the issue is that any diesel engine whether mechanically controlled or EFI goes to full fuel for startup, thats why you get a puff of black smoke on startup.
    The advance solenoid sticks waay open causing the engine to go out of time.. A good tester (launch X-431) can read the data for both run and start. Or contact a Nissan workshop.
  18. #18
    fahadsoulsnatcher911's Avatar
    Jul 2009
    21
    2,876
    7 Post(s)
    well the tb45e and tb48de both are powerful
  19. #19
    Jul 2009
    21
    2,876
    7 Post(s)
    as xulfiqar bhai said also look up the RB series pretty sweet machines
  20. #20
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    is it available ?
Tags for this Thread
