Closed Thread
Page 59 of 92 FirstFirst ... 949575859606169 ... LastLast
Results 1,161 to 1,180 of 1822
Like Tree7535Likes
Thread: 4x4Engaged? Winter in September!!
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Question 4x4Engaged? Winter in September!!
    The picture below shows the upper end of an active or moving unique (Bualtar)Hopar Glacier. Unique? where human life is found above Glacier. Because of constant breaking of ice the glacier is moving right along at about 8 inches per day. The glacier is approximate 20km long in distance. Take with you your best gripping shoes because the surface is very slippery.
    The melt waters fall into the hydro power station, and then carve a constantly changing path & merge with Hispar water & finally into Hunza River.
    I visited this Glacier back in 2002 with my wife & same was witnessed by 4x4 Engaged? the unspoiled beauty of Pakistan in September 2011.
    4x4Engaged? Winter in September!! - IMG 0895 2
    4x4Engaged? Winter in September!! - IMG 0304 2
    4x4Engaged? Winter in September!! - IMG 0763 2
    4x4Engaged? Winter in September!! - wis008 2 2
    The WIS Video:<object width="800" height="450">
    <embed src="http://vimeo.com/moogaloop.swf?clip_id=31417763&server=vimeo.com&sh ow_title=1&show_byline=0&show_portrait=0&color=00a def&fullscreen=1&autoplay=0&loop=0" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="800" height="450"></object>
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
  2. #1161
    Sojourn's Avatar
    May 2007
    47
    363
    I spoke with his elder brother Ali Madad when the the plan was for July....
    Interesting hairdo...
    Eagles's Nest is right up there.....
    Quote Originally Posted by Janj View Post
    4x4Engaged? Winter in September!! - 48
  3. #1162
    Sojourn's Avatar
    May 2007
    47
    363
    The next block-buster hollywood movie will be based on this...Eagleman....
    it is a mythical character from a mythical valley...A Lost Horizon....
    If you lift open the headgear you will see a man insisde it....
    Rumor has it that someone from the gang dorned the suit to verify himseld if this thing flies.....
    =Janj;3040888]Gora loug don't like stuffed one so they found a solution
    4x4Engaged? Winter in September!! - 23[/QUOTE]
  4. #1163
    Sojourn's Avatar
    May 2007
    47
    363
    Oyeeee Hoyeeee...Mardala
    Whata place to unwind...an stay endlessly at this place....
    Marvellous place to gather the thoughs to reflect and write and rewrite and rewrite..and then publish
    4x4Engaged? Winter in September!! - 34
  5. #1164
    Sojourn's Avatar
    May 2007
    47
    363
    Shabaash hei banday per jiss ne yeh architecture socha aur build kiya
    Aur shabash hei photographer per bhi...kia angle hei..
    4x4Engaged? Winter in September!! - 40
  6. #1165
    Sojourn's Avatar
    May 2007
    47
    363
    Zul dar Zulm
    Sitam dar Sitam
    Ghanzab dar Ghazab.....
    Ab jaan lo gey hamari aisiee photowain laga ke?
  7. #1166
    Sojourn's Avatar
    May 2007
    47
    363
    In the last pic...the building appears to be a medieval castle
  8. #1167
    Sojourn's Avatar
    May 2007
    47
    363
    Gorgeous....I'd give an arm and a leg to get to this place
  9. #1168
    Sojourn's Avatar
    May 2007
    47
    363
    whats in the middle of the pic? A monument? Any image? A message? Ya phir Ufone ki advertisement?
  10. #1169
    Sojourn's Avatar
    May 2007
    47
    363
    Am I seeing things or someone sitting on the rock? Sync perhaps? Sync...LT sync
    Quote Originally Posted by syncview View Post
    Good morning janj
    4x4Engaged? Winter in September!! - Peaks 1
  11. #1170
    Sojourn's Avatar
    May 2007
    47
    363
    Drop-Dead-Gorgeous sequence of pictures...
    Wiki:
    Hunza Peak lies in the westernmost subrange of the Karakoram range along with the Ladyfinger Peak (Bublimating). It lies on the southwest ridge of the Ultar Sar massif, the most southeasterly of the major groups of the Batura Muztagh. The whole massif rises precipitously above the Hunza Valley to the southeast.
    Bublimating, while having little prominence above the saddle with nearby Hunza Peak, is particularly notable for being a sharp, relatively snowless rock spire among snow peaks.
    4x4Engaged? Winter in September!! - Peaks 4
    4x4Engaged? Winter in September!! - Peaks 5
    The peak on the right is Ultar II (higher than the Hunza peak) in the pic above
    4x4Engaged? Winter in September!! - Peaks 19
    Wiki: Hunza Peak (centre) with Bublimotin (Ladyfinger Peak) on its left, the southwest ridge of Ultar Sar (resp. Bojohagur Duanasir) on the very right. All of them are part of the Batura Muztagh in the Karakorams in Pakistan
  12. #1171
    Sojourn's Avatar
    May 2007
    47
    363
    Sync lagat hei aaj tu mar ke hee dum lega...hadd hoti hei stunning pics ki bhi
    ...covered by clouds!
    4x4Engaged? Winter in September!! - Peaks 14
  13. #1172
    Sojourn's Avatar
    May 2007
    47
    363
    I wouldn't blame janj & Co for finding the Lady.....sochnay wali baat hei agar Lady ki Finger aisee hei tu phir lady kaisee ho gee...Yaar sync ab such such batay de kahan hei woh Lady?
    Bublimotin, Bubli Motin, Bublimating or Ladyfinger Peak, is a distinctive rock spire in the Batura Muztagh, the westernmost subrange of the Karakoram range in Pakistan. It lies on the southwest ridge of the Ultar Sar massif, the most southeasterly of the major groups of the Batura Muztagh. The whole massif rises precipitously above the Hunza Valley to the southeast. Bublimotin, while having little prominence above the saddle with nearby Hunza Peak, is particularly notable for being a sharp, relatively snowless rock spire among snow peaks. This, combined with its height above the valley, makes it quite eye-catching; hence the distinctive name. It provides a 600 m (1830 ft) rock climb (with a very serious alpine approach) and has been the scene of some notable paragliding.
    4x4Engaged? Winter in September!! - Peaks 22
    other views:
    4x4Engaged? Winter in September!! - Peaks 20
    4x4Engaged? Winter in September!! - Peaks 21
    Janj and company tried to find the Lady but
  14. #1173
    Sojourn's Avatar
    May 2007
    47
    363
    Sync tu chahta kia hei akhir?????? Heart beat, Blood Pressure, shooting out of the window....calling 911 (WIS)
  15. #1174
    Sojourn's Avatar
    May 2007
    47
    363
    Veise last pic ko dekh ker lagta hei ke you guys actually climbed the Rock-o-Poshi itself...at least that's what it looks like....
  16. #1175
    Sojourn's Avatar
    May 2007
    47
    363
    Five-star pictures...
    Hunza Valley below and the snow covered peaks are part of the Rakaposhi Range.
    4x4Engaged? Winter in September!! - Peaks 6
    4x4Engaged? Winter in September!! - Peaks 11
    4x4Engaged? Winter in September!! - Peaks 12
    4x4Engaged? Winter in September!! - Peaks 13.....
  17. #1176
    Sojourn's Avatar
    May 2007
    47
    363
    The best is yet to come.....WIS
  18. #1177
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    aala commentry JT... aap bhi chah gaey ho.... truly excellent batch by sync..
    Still Play with Mogs... DeeMog 421.129 1986... http://www.youtube.com/user/DeeMog421
    http://www.pakwheels.com/forums/4x4-clubs-off-roaders-suv/87109-team-unimog-punga-project
  19. #1178
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    Stone please upload truly asia wali pictures.... i am sure viewers will enjoy...
  20. #1179
    bugzy1's Avatar
    Mar 2006
    Riyadh
    35
    1,434
    yaar ub hui hey Good Morning .... what a a place !!!!
    and the pics are staggering
    bravo! shooters !!
    Bugged for Life....Easily Distracted by Land Rovers
  21. #1180
    nOmS6's Avatar
    Jan 2011
    Select City
    41
    957
    Thumbs up Sitting in the balcony
    Thank you guys for your appreciation. Sync's captures are truly amazing no doubt.
    and here is the icing on the cake
    These views were from our room balcony ! Yep, waking up at Eagles Nest or having evening tea in the balcony, these are the views that give you company.
    Look to your right: Hunza peak, Lady finger, Ultar 2
    Look ahead (11 o clock to be exact Rakaposhi
    Look down and one can see the whole of the Hunza valley below. Amazing place to stay !
    www.facebook.com/NaumanShafiquePhotography
    Twitter @lostinwrlds Google +nomsclick
Closed Thread
