Results 1 to 5 of 5
Thread: 4WD Experts, help needed
    GtiR's Avatar
    Feb 2004
    30
    1,317
    21 Post(s)
    Default 4WD Experts, help needed
    is there any difference in shape b/w 1995 and 1996 SURF?
    Help needed...thanx
    TURBO DIESEL!!!!!
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    There was a model facelift ( KZN185Ws) which we refer to ad the SSR-Gs. But the KZN130W had slight cosemetic tid bits here and there. The front bumper is the give away. The mid to late 95 versions have a two piece unit with a crome fender and black dam or bottom end. The Late 95 early 96s have a uniform color with the fender flares matched. The options have been played around quite a bit so you really have to have a keen eye.
    |||||||||||||||||||||||||||||| C2G - GARAGE | SHOP | TUNE +92 346 8776643 |||||||||||||||||||||||||||||||
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Anythings possible, what matters is your dedication. Its not just bumpers. The 185 has an additional line traversing the lenght of the body. The Flares are bigger ont he 185. The front accessory panel is differnt. Lowered ride height. The rear's much simpler. The combination lamps are straight swap. The rear suspensions' slightly modified as are the front struts. You know the other difference. Just swap the coach work. Straight fit, less work!
    GtiR's Avatar
    Feb 2004
    30
    1,317
    21 Post(s)
    Thanx for the info adeel bhai....the rear is quite similar of 130 and 185, but the main difference is in front....ne ways thnx for the info
    TURBO DIESEL!!!!!
    Voyager's Avatar
    Aug 2004
    42
    3,744
    3 Post(s)
    Cosmetic changes were made to 1995 Model as compare to 1993 models. Mechanically the only difference B/W 1995/1996 is that Intercooler was attached to July 1996 Models. Both 1995 & 1996 came with KZN185W.
    KZN185W started in December 1995 and KZN130W started way back in August 1993.
    Modifications produced from July 1996:
    Only 2 Hilux Surf models were introduced in 1996 as comared to 1995 Models:
    AT / MT=Drive Trans
    G / D= Fuel Type
    3.0/2.7/3.4=Displacement Liters
    1: SSRG
    RCSR-G intercooler attaching Turbo Diesel, touring package equipped car wide body
    AT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAPGH
    2: SSRG
    RCSR-G intercooler attaching Turbo Diesel wide body
    AT D 3.0 1KZ-TE
    Modifications for Hilux Surf Model 1995 produced from December 1995
    AT / MT=Drive Trans
    G / D= Fuel Type
    1 SSR-G
    MT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAMGT
    2 SSR-G
    AT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAPGT
    3 SSR-G
    AT G 3.4 5VZ-FE
    Frame: E-VZN185W-GAPGK
    4 SSR-V
    MT G 2.7 3RZ-FE
    Frame: E-RZN185W-GAMVK
    5 SSR-V
    AT G 2.7 3RZ-FE
    Frame: E-RZN185W-GAPVK
    6 SSR-X
    AT G 2.7 3RZ-FE E-RZN185W-GKPXK
    7 SSR
    MT D 3.0 1KZ-TE
    Frame: KD-KZN185G-GKMST
    8 SSR-X
    MT G 2.7 3RZ-FE
    Frame: E-RZN185W-GAMXK
    9 SSR-X
    MT G 2.7 3RZ-FE
    10 SSR-X
    AT G 2.7 3RZ-FE
    Frame: E-RZN185W-GAPXK
    11 SSR-X
    MT G 2.7 3RZ-FE
    12 SSR-V
    MT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAMVT
    13 SSR-X
    MT G 2.7 3RZ-FE
    14 SSR-X
    AT G 2.7 3RZ-FE
    15 SSR-X
    AT G 2.7 3RZ-FE
    16 SSR-V
    AT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAPVT
    17 SSR-X
    4WD AT G 2.7 3RZ-FE
    18 SSR-X
    AT D 3.0 1KZ-TE
    Frame: KD-KZN185G-GKPXT
    19 SSR-X
    MT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAMXT
    20 SSR-X
    MT D 3.0 1KZ-TE
    21 SSR-X
    AT D 3.0 1KZ-TE
    Frame: KD-KZN185W-GAPXT
    22 SSR-X
    MT D 3.0 1KZ-TE
    23 SSR-X
    MT D 3.0 1KZ-TE
    24 SSR-X
    AT D 3.0 1KZ-TE
    25 SSR-X
    AT D 3.0 1KZ-TE
    26 SSR-G
    MT D 3.0 1KZ-TE
    27 SSR-X
    AT D 3.0 1KZ-TE
    28 SSR-G
    AT G 3.4 5VZ-FE
    29 SSR-G
    AT D 3.0 1KZ-TE
    It would "go places where tankers quit and birds would go back exhausted." *****Willys MB*****
