Results 1 to 2 of 2
Thread: BJ73 - Urgent Advice Needed
    jehanzebnasir's Avatar
    Aug 2011
    525
    21 Post(s)
    Question BJ73 - Urgent Advice Needed
    Dear Pakwheelers
    Nowadays I am in the process of acquiring a BJ73, but the problem is that instead of original 3B it has a 2L engine installed in it. I searched pakwheels and got this useful information for comparsion purpose. As I am a prospective newcomer to 4x4 club dont know the effect of these changes of gear ratio h/l ratio and axle ratio. Your expert advice will be highly appreciated.
    ENGINE
    Type
    Model 3B, diesel engine, OHV
    Cylinders
    in-line 4
    Bore x stroke
    102.0 x 105.0mm
    Displacement
    3.431cc
    Compression ratio
    20.0
    Maximum net power
    98PS/3,500 r.p.m.
    Maximum net torque
    23.0kg-m/2,200 r.p.m.
    Gasolin tank capacity
    90 liters
    TRANSMISSION
    5 M/T
    Gear ratio
    : 1st 4.843
    : 2nd 2.618
    : 3rd 1.516
    : 4th 1.000
    : 5th 0.845
    : reverse 4.843
    TRANSFER
    Gear ratio
    : high 1.000
    : low 1.960
    Axle ratio
    4.111
    ENGINE
    Type
    Model 2L-T, diesel engine, turbo
    Cylinders
    in-line 4
    Bore and stroke
    92.0 x 92.0mm
    Displacement
    2,446cc
    Compression ratio
    20.0
    Maximum net power
    85PS/4,000 r.p.m.
    Maximum net torque
    19.2kg-m2,400 r.p.m.
    Fuel Tank Capacity
    90 liters
    TRANSMISSION
    5 M/T
    Gear ratio
    : 1st 4.313
    : 2nd 2.330
    : 3rd 1.436
    : 4th 1.000
    : 5th 0.838
    : reverse 4.220
    TRANSFER
    Gear ratio
    : high 1.000
    : low 2.295
    Axle ratio
    4.875
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Basically there is a mismatch of the engine and the gear+diff. The 3B puts out a lot more power and torque and has longer (numerically lower) diff ratios (4.11) than the 2LT models (4.875)....
    While in 1st, 2nd and 3rd gears this will be somewhat offset by shorter (numerically lower) gear ratios, in 4th and 5th gears there will be significant difference in power & torque... ( I am too lazy today to do the maths for comparison but you can get the precise comparison if you multiply gear x diff ratios for each setup)....
    Overall you will end up with a more economical drive but the car will struggle for power in climbing and offroading situation. Assuming that the engine is a later model 2LT in good shape, its possible that the drive is still quite enjoyable on the road, highways and flat tracks. On steep climbs and offroading the engine will sit out of its comfort zone particularly at the low end. The 2LT engine will also put out a lot more black smoke than it would with its original setup (though that is also dependent on the pump/turbo settings)....
    If however the engine is worn out, you will possibly have issues as its likely that the low end is not putting out as much torque as it should and the car will struggle a lot more....
    "If YOU don't believe in what you're doing it'll never work."
