Salam all,
I've been looking at a CJ-7 recently. Which runs on a 2C engine (2.0D waala).
However, i've been having reservations about such a small engine. On a test run, i could go upto 80km/hr on 5th gear on 3000 RPM. Pushing it higher would mean a very high rpm on 5th gear. However, the Jeep had very high tires, engine's pump needed cleaning, maintenance etc.
My question was, if i have the engine cleaned and services, thinner tires (it has very wide ones), higher gear ratio, would i be able to achieve a lot higher speeds?
I need to have a Jeep that can go 110km/hr at least for longer trips. Would a 2C engine be too small for this?
If not, then what about the 3CT-E Engine? Would it be able to achieve such speeds? And any idea how much a kabli one would cost in pindi?
Also, what are your thoughts on the 2L-T? I've often read people here advising against the 2L. What consumption can i expect from a 2L-T?
Thank you for your time.
