Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree6Likes
Thread: Looking for Dual battery system
    naveedmerchant's Avatar
    Aug 2006
    51
    113
    Default Looking for Dual battery system
    I am looking for dual battery system for my 4x4 something similar to ARB Battery Systems | Products | ARB 4x4 Accessories or Battery Isolators & Relays Is there anyone who can do this locally?
    These are great power source while camping out
    ahmed.ejaz's Avatar
    Aug 2010
    32
    93
    2 Post(s)
    bro i'm looking for same, my hilux is 12v but i want this to reserve 2nd battery for ups usage, winch and camping - kindly also let me know what you plan. it will eventually by ironman or arb for me as this has to be very reliable system. awaiting your reply.
    ahmed 0321 3531111
    Far back as I can remember, I always wanted to be a gangster - Goodfellas
    Aug 2006
    51
    113
    I had posted an equiry on australia well known forum on explorz on link HJ60 power inverter issues @ ExplorOz Forum and they suggest to opt for Battery Isolators & Relays and another one very good is www.4wdsystems.com.au
    For heavy duty applications (winches etc) you need a 450amp Isolator with heavier cabling. But these are very expensive. Cost of kit is $277 (for 100amp kit), $340 (for 180amp kit) and $449 (for 450amp unit) and these are Australian dollars.
    Lets research this out locally
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Easy solution
    Put another identical rating battery in parallel in Engine bay.
    U will have 12 V with double rating amps.
    The only issue will be alternator which on most SUV's is strong enough to charge both batteries when engine is running.
    Aug 2006
    51
    113
    Quote Originally Posted by baigaqeel View Post
    Easy solution
    How about if we can make a manual hand system with a meter on board on dashboard which enables to connect the 2nd battery to alternator once the primary battery is fully charged and then disconnect by a hand switch system once 2nd battery gets fully charged
    ahmed.ejaz's Avatar
    Aug 2010
    32
    93
    2 Post(s)
    Easy solution
    yes it is 12v and higher current - but i believe that will damage your starting system and injectors like in 1kd
    alternate battery system, charges 2nd battery once 1st is fully charged, its uses 2nd battery when you turn the main system knob, 2nd battery is always reserved for bad situation / emergency / winch / ups / camping - so that your primary battery is always safe.
    ahmed.ejaz's Avatar
    Aug 2010
    32
    93
    2 Post(s)
    Quote Originally Posted by naveedmerchant View Post
    yup if you can manage that, please let me know - i'm much interested and looking forward to it
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by ahmed.ejaz View Post
    Alternator has no idea it is charging 1st battery or 2nd.
    What will happen that the charging current will be divided into 2 batteries equally & if somehow u have a strong battery with a weak one in parallel then it will not charge the weak one because the regulator will limit the charging current.
    So when u want to have 2 batteries in system in parallel then get 2 new identical rating batteries & connect thats it
    Mind u it has nothing to do with starting system & injectors.
    The system will draw whatever current is reqd & if somehow the battery is weak it will draw more current on the expense of volatge
    Which we say that Battery is weak
    ahmed.ejaz's Avatar
    Aug 2010
    32
    93
    2 Post(s)
    Salam, bhai as you have mentioned, it depends on the system rather than charging two batteries at same time, the arb or a specific circuit for this purpose will first charge primary battery to 13v then stop charging it, and start charging secondary battery. You have a visible led screen to see how much which battery is charged. Furthermore you will have option to only use secondary battery only, while saving primary. Kindly have a look at arb / tjm dual battery systems. You would get a better idea about it. I still believe that two batteries in parallel wouldn't solve the purpose.
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    I posted an easy & quick solution
    Market is full of hi-tech gadgets
    It is up to buyer how much he is willing to spend.
    Aug 2006
    51
    113
    this seems like an easy quick and cheap solution..
  12. #12
    ahmed.ejaz's Avatar
    Aug 2010
    32
    93
    2 Post(s)
    agreed
  13. #13
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    check with UNIMOGERs in this forum. They have plenty of such solutions to COMBAT the power desire in wilderness !
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  14. #14
    Aug 2006
    51
    113
    Quote Originally Posted by capsat View Post
    I wasnt able to find UNIMOGER within the PWs search
  15. #15
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    lol... yes we do have solutions to combat the power desire in wilderness BUT related mostly to Unimog and also 24v... hence we already running with 2 batteries again 24v and not related to query running on this thread... i have seen Nissan and LCs with dual batteries and i guess copying the solution from there wud be the easiest and cheapest way...
    Still Play with Mogs... DeeMog 421.129 1986... http://www.youtube.com/user/DeeMog421
    http://www.pakwheels.com/forums/4x4-clubs-off-roaders-suv/87109-team-unimog-punga-project
  16. #16
    fihsak's Avatar
    Aug 2004
    Select City
    32
    1,749
    19 Post(s)
    2 Thread(s)
    Q#1. Which 4x4 you are having to convert to dual battery system?
    Q#2. What is the ampere rating of your current/OEM generator installed?
    Q#3. Have you talked or checked with your electrician?
    When Nothing Else Work, Team Unimog has the Solution....
  17. #17
    fihsak's Avatar
    Aug 2004
    Select City
    32
    1,749
    19 Post(s)
    2 Thread(s)
    this link MIGHT help you out up to some extent
    Dual Battery Systems and Alternator charging
  18. #18
    Aug 2006
    51
    113
    Quote Originally Posted by fihsak View Post
    This is perfect. Do you know anyone in Karachi who can make this ?
  19. #19
    Basharatu's Avatar
    Mar 2007
    Basco
    2,323
    23 Post(s)
    Thumbs up
    Try key words like "mog", "mogger", "mogged", "mogging", "mogest", "moggie"
    Thumbs on the solution suggested by fihsak!
    When Nothing else do the Job "ҐЄຊ๓ પฑḭ₥φ౸" has the solution. http://www.facebook.com/team.unimog
  20. #20
    fihsak's Avatar
    Aug 2004
    Select City
    32
    1,749
    19 Post(s)
    2 Thread(s)
    Sorry Sir... I am based in Peshawar would have sorted it out for u here, by the way which SUV u are having and is there any space in the engine bay for the second battery and what is the ampere rating of your Generator?
