Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By AmeerUsman
Thread: Diesel - Patrol engines, Mobil oil difference
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    Default Diesel - Patrol engines, Mobil oil difference
    Dear Experts
    I have 1996 Prado with 1kz engine , 3000 Diesel Turbo. In first 10 months i used the normal mobil oil that is used for diesel engines from toyota, PSO or shell and it was giving average millage of 5.5 km/litre. 2 month back i went to Total for oil change, the owner of the pump is my friend, he advised me to use semi synthtic oil ( 10 w 40 ) that is usually considered for patrol engines. HE said this will increase ur car milleage and pick. Soon after changing the oil i noticed increase in pick and millage from 5.5 to 6.7km/l. I m happy with this change. I know 10 w 40 oil is thin compared to other diesel engine oils, so instead of changing at 3500km i replaced it at 2500 km.
    I just want to confirm from experts that is this ok or this oil harms the engine.
    Regards
    Asad Sethi
    Founder, FRONTIER 4X4 CLUB : Adventure begins where road ends!
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    Anyone???
    6Forward's Avatar
    Feb 2012
    203
    Brother
    10W-40 is viscosity grade of engine oil. U can also 10W-30. For identification of engine oil whether for gasoline or diesel engine, check API grading like CI-4, CH-4
    So check the product which r u using of its API grading
    The diesel engine required higher TBN (Total Base Number) then gasoline engine oil.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    API Rating of diesel engine oil starts with C e.g, CF, CH,CI etc. For petrol engines This starts with S e.g, SF.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by asadsethi View Post
    Dear Experts
    Regards
    Asad Sethi
    changing oil at 3500 km?? what kind of service?
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Dear Experts
    Regards
    Asad Sethi
    It will not harm your engine. The reason why you are probably seeing an increase in mileage is because you were using 20w50 oil before. Now you've gone to a thinner oil which will give your engine parts lesser friction due to the lower viscosity (fluid friction). Changing oil at 2500km, that too semi-synthetic oil, is an overkill. You should be just fine at changing at 5,000km intervals.
    Rao.
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @asadsethi
    I always use 15W-40 viscosity oil (Diesel specific) in my Diesel cars & used to change oil @ 5000Km & never got performance & oil reduction etc type issue.
    Mostly the modern oil are complaince to both (Spark ignition & Compress ignition) IC engines so it shudnt harm But u must find some Modern Engine Oil specifically for Diesel complaince.
    May not in the line of most Hi tech But i have found Delo Gold very good lube to be used in Diesel Engines & easily available all over Pakistan.
    Exploring Machines is my Passion...
