Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: Gen 1 Vs. Gen 2 Pajero in DIESEL Fuel Consumption
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Question Gen 1 Vs. Gen 2 Pajero in DIESEL Fuel Consumption
    Which one is Economical?
    Gen 1
    Engine 2.5 4d56 Turbo
    Gen 2
    Engine 2.8i Exceed
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    both engines have same fuel consumption, but different power output. It is vital that the engine be adjusted carefully - e.g. the old 4D56 pump has a mechanical boost aneroid on the pump which increases fuelling under boost.
    Also vital is correct timing of the engine with a dial gauge, calibrated nozzles, new head bolts, new con-rod bolts and a descaled cooling system.
    towaseem's Avatar
    Oct 2005
    39
    330
    3 Post(s)
    My Pajero Gen 1, 2.5 Trubo does 6 km/liter, local. Dont know about long route.
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    mine non turbo 2400cc, gives me around 11-12km per liter in city.
    cougar75's Avatar
    Jun 2007
    Rawalpindi
    41
    235
    dear owners
    2.5tdi easliy gives 12 kmpl provided you donot push gas to floor every time you start from red light or halt ,mostly EGR is responsible for bad economy not the pump EGR is located close to turbo can be cleaned as DIY if you ve little techanical knowledge
    060276's Avatar
    May 2009
    27
    1,859
    43 Post(s)
    ^^ what is EGR ..Please explain a bit ?
    Umer Siddiqui ... Inline Six .... ** 2JZ-GE **
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    EGR = Exhaust Gas Recirculation
    In Diesel Engines they get filled with Burned exhaust dirty/black/sooty smoke which usually start effecting/blocking airflow, increase engine oil acidity, & in later models of pajero: butterfly valves(fitted to intake manifold just before cylinder head intake ports).
    joyee's Avatar
    Nov 2012
    Bowral
    Mine pajero Cover 5km distance in 1 litter, is it conceivable or me should to check it any technician for better understanding?
    car rentals gold coast
