both engines have same fuel consumption, but different power output. It is vital that the engine be adjusted carefully - e.g. the old 4D56 pump has a mechanical boost aneroid on the pump which increases fuelling under boost.
Also vital is correct timing of the engine with a dial gauge, calibrated nozzles, new head bolts, new con-rod bolts and a descaled cooling system.
