Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By Xulfiqar
  • 1 Post By SER_GTR
Thread: mini pajero heating issue
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    Default mini pajero heating issue
    assalam o alaikum
    hope u all are fine.
    recently i pruchased a mini pajero, the problem i am facing are heatup issues after overhauling. All the work was done by a good mechanic but i am just stuck in this mini jeep. The work done on the engine is crank grinding, piston sleeves, rings, head valves etc.
    Now the problem is dat the vehicle is overheating in daytimes and when u press the throttle hard. the temperature needle goes to half, the rpm needle fluctuates i.e from 1500 rpm to 2000 rpm then drops again to 1500. this happens every second if i drive it with a light foot then its ok in evening and even in daytime.
    Suggestions needed from professionals. Mileage after overhaul is abt 400 km. Mechanic says i will tune the engine after 100km, it all goes fine then but i am not satisfied by him.
    I also wanted to swap the engine to 1100cc but the mechanics said that u also had to change the differentials etc wid engine,i searched for the same engine but not a single engine is available in bilal gunj.
    note: its a 16 valve turbo intercooler 660cc.
    regard
    haroon
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    wait for 1000km!!
    Pakistan <3
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Does your engine have a mechanical fan or an electric fan?
    and you need the thermostat valve in this engine because the thermostat is positive bypass type, meaning when the engine heats up to open the thermostat all water/coolant is forced to the radiator.
    celica's Avatar
    Dec 2004
    4,074
    20 Post(s)
    2 Thread(s)
    Right Xulfiqar bhai.
    ALWAYS BE POSITIVE
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    aoa,
    as its is a 03 model so its having an electronic fan which is attached to the radiator.
    thermostat valve is present but mechanic unplugged the grip of that pipe to make fan direct
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    Actually its not heating up, its a tps fault, when throttle body gets hot or something like this, the sensor become faulty. yesterday i drove abt 100 km constantly so dere is no increased coolant in the reservoir bottle. Today i will see the mechanic as mileage is 550 km now and he wants to tune the engine
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    how can your mechanic "tune" this engine.
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    only adjustment of tappets.
    marygrace's Avatar
    Jun 2012
    New York City
    that's actually a minor issues upon purchasing a new car that is why there is a need to have it fully checked up and make sure that everything seems to be working fine. air conditioning indianapolis
    hamadewf's Avatar
    Jul 2014
    11
    Aoa All,
    I have bought a mini pajero 96 model 20 valve automatic 660c with turbo and have same heat up problem on ac. After a while car gets heat up slighlty more than half and starts missing on high rpm. I have changed radiator got fuel tank serviced and have done everything but the problem presits. Any suggestions please?
    tahasoomro's Avatar
    Nov 2009
    28
    882
    11 Post(s)
    Quote Originally Posted by hamadewf View Post
    Aoa All,
    Contact Ajmal Bhai if you are in Karachi
  12. #12
    hamadewf's Avatar
    Jul 2014
    11
    Thanks. Can you give me his number and address? yes I'm in Khi
  13. #13
    tahasoomro's Avatar
    Nov 2009
    28
    882
    11 Post(s)
    Visit At Back side of Ziauddin Hospital Clifton ask any one about Ajmal Ustad ....
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    the phd in auto?
  15. #15
    tahasoomro's Avatar
    Nov 2009
    28
    882
    11 Post(s)
    the phd in auto?
    Yes Dear
  16. 24-07-2014, 01:17 AM
    Senior PakWheeler
  17. #16
    omarabdullah022's Avatar
    Oct 2012
    2,642
    96 Post(s)
    Quote Originally Posted by tahasoomro View Post
    Yes Dear
    Can he perform a compression test? I need that for a carby cultus..
    Sent from my GT-I9500 using PW Forums mobile app
  18. #17
    tahasoomro's Avatar
    Nov 2009
    28
    882
    11 Post(s)
    Quote Originally Posted by omarabdullah022 View Post
    Yessure
  19. #18
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Phd Refer He His Books So I Can Read And Gain Knowledge
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
