Results 1 to 5 of 5
Thread: Pajero Intercooler 2800 1996)
    NaCC's Avatar
    Dec 2010
    Abbotabad
    246
    2 Post(s)
    Default Pajero Intercooler 2800 1996)
    Hi Got Pajero Intercoller 2800 and its amazing SUV but I have noticed that water from the main Water Bottle and Radiator keep disapearing for the last few months and I have to top it up every week or so,
    What could be the reason for this ? I cant see the radiator being leaked from any where and Car does't get over heated as well.
    Any suggestions plz .....
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    check your radiator cap. Get a genuine one from Mitsubishi or Kabari. Do not use chinese/local versions.
    Moreover there could be a minor leak somewhere in the hoses. You can detect that when the engine is hot.
    NaCC's Avatar
    Dec 2010
    Abbotabad
    246
    2 Post(s)
    Quote Originally Posted by desertdevil View Post
    Hi thanks for your reply, I got the Original Cap on the radiator but Main Issue is water disapearing from the Main Water bottle and when that finished then Radiator level goes down and Engine ligh turns on.
    adeel65's Avatar
    Mar 2011
    36
    314
    4 Post(s)
    check your vehicle mannual few engine require airlock removal from cooling sys after refilling water moreover water is a desi cooling way always use proper coolant which are available in market for reasonable amount,
    Sshhh, Enjoy the sound of calm before the storm.
    Dec 2008
    45
    2,542
    30 Post(s)
    Once you have the colored coolant in it you may also want to check the undercarriage for any possible leaks as with plain water its not detectable. you can also check if your gasket is damaged if you see small bubbles in the radiator when u carry out the first morning start.
