Results 1 to 8 of 8
Thread: Advice needed in disabling airbags - momentarily
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Question Advice needed in disabling airbags - momentarily
    I want to work on the front end of my Prado 90 series and wanted to know if there is a way to disable the airbags. I don't want an accidental deployment.
    Will taking out the fuze for airbags disable them ?
    The work required will be done on a switched off vehicle, do airbags still deploy on a switched off vehicle, if struck hard at sensitive areas?
    Thanks,
    Sarmad
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    pixelzeesh's Avatar
    Jul 2007
    Dubai
    1,496
    6 Post(s)
    Airbag is connected with your seat Belts, if you wear Seat belt that means it will deploy, on a stand by mode where the engine is turned off, even if the key is removed the air bag will still have enough stored battery power to deploy for at least a few minutes
    www.pixelzeesh.com
    Dec 2007
    40
    1,599
    Unhappy
    Quote Originally Posted by pixelzeesh View Post
    I'm a bit confused here .... I know that they will deploy when the seatbelt is worn, but you are saying if the vehicle is stationary and engine switch off they will still deploy, that means they are not connected to the seatbelts!
    Site Banned Follow
    BackToCivicFaiez's Avatar
    Jun 2010
    6,164
    11 Post(s)
    4 Thread(s)
    to my knowledge, not much power is needed to activate the airbags....its all a chemical reaction, not an electric blower that blows up the bags with air...
    @sarmadqureshi: there are collision sensors that activate the airbags....unless you activate them, nothing will happen. im not sure if it has a fuse....installing fuse for airbags doesnt sound rational...
    wat kind of work are you doing?
    Dec 2007
    40
    1,599
    Installing a winch. Need to work on the chassis horns/bump stops
    Site Banned Follow
    Jun 2010
    6,164
    11 Post(s)
    4 Thread(s)
    Quote Originally Posted by sarmadqureshi View Post
    PM "Xulfiqar" or ask 4X4 experts..just to be sure before u start anything.
    pixelzeesh's Avatar
    Jul 2007
    Dubai
    1,496
    6 Post(s)
    Airbag Service Resource | Airbag Replacement FAQ
    Visit this site and it will solve your problem...
    www.pixelzeesh.com
    mani43's Avatar
    Nov 2011
    244
    3 Post(s)
    Check vehicle manual
    for Altis, airbags got deployed only if car is running above 40 kph and got hit from front
