Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Like Tree19Likes
Thread: Jeep Toyota Prado Auto Transmission stops moving once uphill
    goshi_mirza's Avatar
    Mar 2008
    43
    72
    Default Jeep Toyota Prado Auto Transmission stops moving once uphill
    Friends my recently bought toyota prado jeep 1992 model auto transmission is excellent while going on plane road but once stopped and starts moving cannot even climb a speed breaker.Can any one guide me what is the problem.Engine is good.Is it some problem with transmission or diesel pump or what.How to check this out.Should i go to some diesel laboratory with diesel pump
    Shahzad
    Mar 2008
    43
    72
    Shahzad
    hash4u's Avatar
    May 2005
    38
    24,380
    18
    406 Post(s)
    13 Thread(s)
    13
    incomplete description of problem
    how does it move at the first place then?
    does the rpm go up and it still doesnt move?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    does it shift through all gears once moving on plain road?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    do u log maintenance history of vehicle, in near past is there a change of transmission fluid
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Mar 2008
    43
    72
    The transmission seal was leaking and has been replaced a week ago.Complete 9 litres of transmission oil was completed .This problem was also present before the replacement of seal and continues.The jeep changes gears smoothly while driving but once you do a dead stop and even there is a speed breaker ahead the jeep cannot cross it.You have to move back and cross the same with a little speed.The mechanic has told be to get the diesel pump checked.I am worried what even i change/ repair the pump and problem again continues.On highway also the jeep do not go beyond 100 because may be there is a setting of less fuel but stopping on a speed breaker of this powerful jeep is beyond comprehension.Thanks a lot for your support please.
    Shahzad
    Mar 2008
    43
    72
    Will check RPM and get back also
    Shahzad
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    bhai jan problem transmission ka lagta hai diesel pump ya engine ka nahi. keya correct specs ka oil change use kara hai ? ya mechanic nai sarson ka tayl dal kar STP add kar deya chal mayra bhai
    samvaid's Avatar
    May 2010
    39
    562
    65 Post(s)
    7 Thread(s)
    Quote Originally Posted by goshi_mirza View Post
    Very interesting situTion, it seems like a tranny issue not an engine issue.
    it could be as simple as a wornout clutch or coukd be your ecu thay controls ur auto tranny.
    best to do is het it checked ny a transmission mechanic and get his opinion.
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    Could be your torque convertor inside the tranny. is ur prado 2.5 or 3.0 litre?
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Sounds like auto transmission oil is very low or there is some other fault, transmission filters clogged or bad oil.
    Would not recommend driving car around as could result in permanent transmission damage, you should get it checked up first thing!
    "If YOU don't believe in what you're doing it'll never work."
  12. #12
    Mar 2008
    43
    72
    It is 2.5 Diesel .What is tranny and torque converter.what is its function
    Shahzad
  13. #13
    Mar 2008
    43
    72
    which one is the suggested oil i assume it was auto transmission oil
    Shahzad
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    what engine do you have? and what is your approximate acceleration time to 100 km/h from a stop.
  15. #15
    Mar 2008
    43
    72
    I have used WARCO Auto Transmission Fluid Type A and put 9 litres of it in empty gear box .How much approx it will cost for replacement of tranny and torque converter by transmission mechanic.Any knowledge about good transmission mechanic in Peshawar.
    Shahzad
  16. #16
    Mar 2008
    43
    72
    when i push the accelerator on spead breaker at that time RPM also do not rise
    Shahzad
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    install a new fuel filter, and run the engine from a bottle of fuel in the engine bay, Seems like your engine is not getting any fuel. Choked filters cause this. Does the engine behave correctly without any drive load, meaning if you rev in Park or Neutral, It should idle normally, all injection lines should have even pulsing and the noise should be minimal.Also disable the EGR and block it off. You should also inspect the inlet manifold for gunking up and clean it out.
  18. #18
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    take that fluid out - your transmission requires DX3 not type A. And firstly get the engine working correct. Low fluid in a transmission or bad fluid will not cause lugging but would have slip - great slip like a worn clutch plate in a manual.If you want to get some remedy then put your post in one section with all information, otherwise it will become a jumble to solve. Rule 1 of automatic transmission troubleshooting is to verify the engine is working correctly. If the engine cannot put out any usable torque the transmission will not work properly.
  19. #19
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Transmission = Tranny, Torque Converter(read) is clutch for Auto transmission. You need to relax a bit as expected out of my question the problem is wrong transmission fluid replace fluid alongwith the transmission filter then drive vehicle if situation improves to certain positive side then you need to isolate the problem area in engine which also need certain adjustment. Please consolidate all problem in one thread as Xulifiqar correctly said. in your next post please mention the odometer reading and if there is any maintenance history for engine oil oil filter & fuel filter changes.
    no need to panic for transmission swap have bit of patience follow up (subscribe ) this thread you may be fortunate to save your transmission with help from Xulfiqar replies
    - You are posting in 2 places and its quiet confusing for many of us
  20. #20
    Mar 2008
    43
    72
    OK Bros sorry for inconvience . Me slightly poor in computer and was worried and wanted guidance.Now this thread is closed i will only use one thread
    Shahzad
