Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 46
Like Tree19Likes
Thread: Jeep Toyota Prado Auto Transmission stops moving once uphill
    goshi_mirza's Avatar
    Mar 2008
    43
    72
    Default Jeep Toyota Prado Auto Transmission stops moving once uphill
    Friends my recently bought toyota prado jeep 1992 model auto transmission is excellent while going on plane road but once stopped and starts moving cannot even climb a speed breaker.Can any one guide me what is the problem.Engine is good.Is it some problem with transmission or diesel pump or what.How to check this out.Should i go to some diesel laboratory with diesel pump
    Shahzad
  2. #21
    Mar 2008
    43
    72
    Sorry Bro Now i will only use this thread
    Shahzad
  3. #22
    Mar 2008
    43
    72
    Odometer reading 222756. No maintenance history since bought two weeks ago and drove from Jhelum to Nowshera with tranny seal leaking.Maybe little left till nowshera because some oil also seen beneath the jeep once parked at Nowshera
    Shahzad
  4. #23
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    you need some serious maintenance in one GO. before that like Xulfiqar asked is your vehicle revving up normal when parked - P & N - if it is stalling to roar ( sans lay rahi hai ) you need to do following before heading for some USTAAD to butcher the engine & transmission
    1. change fuel filter
    2. change air cleaner
    3. change transmission oil filter in transmission
    4. refill tranmssion fluid with correct SAE rating fluid as mentioned by Xulfiqar
    if there is positive improvement in performance but not enough do post clear cut findings if there is any place near you with a Toyota scanner request the shop to pull the error codes ' do not reset ' and post the code details if conveneint.
    many of us are here on forum in evenings so do whatever is possible during day and post here for further input.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  5. #24
    Mar 2008
    43
    72
    Sorry again this thread is the only thread now and still open for your valuable comments friends
    Shahzad
  6. #25
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    One member of this forum 4x4 user Suhaib Kiani of Islamabad Jeepers Club has also replied to this thread if you are Highly worried and suffering from anxiety send an email / PM to get in touch 1 to 1 you both are in same town and he will be able to help you most forum members are polite enough to extend helping hand with their experience & trusted mechanics.
  7. #26
    hayzin's Avatar
    Jul 2006
    1,625
    86 Post(s)
    2 Thread(s)
    I faced a similiar problem 2 years back when I first bought my LC. It would not do well on steep slopes and always felt sluggish. That is not a fun feeling. Here is what I did:
    1. Got the clutch replaced (manual transmission)
    2. Changed all possible oils
    3. Got nozzles serviced
    4. Air filter service (for oil based filters)
    5. Went to a reliable diesel lab for tune ups
    Make sure you go to the right place to get all these things done, especially the diesel lab, clutch and nozzles. The Kiani brothers are a great resource for you to take help from in Pindi.
    Good Luck. Let us know what works out in the end.
    4x4 for life!
  8. #27
    Mar 2008
    43
    72
    DX3 is not available here.DX (Dexron )4 cost Rs 650/litre and korean Zic Rs 450/litre.Which transmission oil should i use
    Shahzad
  9. #28
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    DX 3 SAE 10W rating ka hota hai ap try karyeay agar ap ko SAE 10W ka koi ATF mil jai tou bhi kam chal sakta hai
    ZIC Mr Syed Iftikhar Shah (0300-8373975) Manager sales yeah bhi ap ki help kar saktay hain
  10. #29
    Mar 2008
    43
    72
    Please suggest/address /tel some good transmission mechanic in Nowshera,Peshawar,Rawalpindi or Jhelum please
    Shahzad
  11. #30
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    keyon bhai jan keya kisi islamabad walay member nai ap ki koi help nahi kari ya ap ko choona lagwana acha lagta hai
  12. #31
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by goshi_mirza View Post
    seems like your patience have run out - I still recommend sending a PM / email to IJC members they are all seasoned off-roaders and know right people for this kind of job
  13. #32
    Mar 2008
    43
    72
    Dear Friends Although still using WARCO Auto Transmission Fluid Type however changed fuel filter, changed air cleaner , changed transmission oil filter. RPM increases once parked or neutral but once standing on a rising road and go to DDrive then RPM do not rise much on acclerator. I think i need to go for replaced of auto transmission cluth. Need your guidance as well as expenses involved.Will also try to contact IJC.Waiting for your response
    Shahzad
  14. #33
    Mar 2008
    43
    72
    Hello Friends Guidance to go for replacement of auto transmission cluth.
    Shahzad
  15. #34
    azkhan's Avatar
    Mar 2004
    28
    517
    20 Post(s)
    Default Warco
    Is the ATF used Warco Type A? If yes I think that ATF is not compatible with your transmission because its the earliest form of ATF. Check with the owners manual (I think it must be atleast DX2). In case its not compatible change is ASAP. In case of dexron 4 I think its backward compatible. Zic ATF III is widely available.Just my
    //.....Don't bully Korean cars.......//
  16. #35
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3987 Post(s)
    94 Thread(s)
    6
    There are a total of 4 clutch packs in your transmission and hold about 20 friction plates in total, If they were slipping or worn out, then you would have high rpm with less drive, which is the opposite of what you have - you have no engine torque to spin the transmission. I dont understand that you say it works when moving, Have you not driven a proper diesel LC?? It should tear off its rear tires.Without the engine in good tune the transmission cannot work at all, Low fuel supply to the diesel pump caused by a dirty fuel filter or a bad vane pump inside the IP will cause a great loss of power, Also note that if the internal pressure of the pump is messed up by the return banjo bolt it will also show the same problems as low fuel. For testing you can get a cheap inline fuel pump and make it feed the IP - also ensure that the pump timing is correct, all nozzles spraying at exact same pressure (depends on the engine type), the engine is atleast at 90*C temperature (half gauge) - a cold diesel engine will not make any power, the EGR is not stuck open or corroded (block it off completely) and the valve clearances (tappets) are at correct clearance.
  17. #36
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3987 Post(s)
    94 Thread(s)
    6
    can the engine idle itself correctly with A/C in original setup - which has no idle up dashpot on the pump. The engine itself has enough torque at idle to handle the A/C compressor load.
  18. #37
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Have sent you a PM with contacts to our mechanic friend who would be happy to take a look at your car and advise you.
    Best,
    SK
    "If YOU don't believe in what you're doing it'll never work."
  19. #38
    TLCFJ40's Avatar
    Sep 2006
    37
    1,784
    7 Post(s)
    Bro just get ur tranny serviced, and get it done by a proper mechanic who knows trannies inside out. If u cant find a mechanic i can hook u up with mine. I cant exactly understand ur propblem but it could be anything from a damaged tranny cable faulty converter to a choked up filter.
    Toyota All The Way !!!!!!!!!
  20. #39
    Mar 2008
    43
    72
    Thanks a lot friends for you value added additions and detailed guidance upto minute points.I will go through all these with mechanic and will get back
    Shahzad
  21. #40
    Mar 2008
    43
    72
    Xulfiqar Bhai the engine idle itself correctly with A/C in original setup and no problem at all.Half self start
    Shahzad
