Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Like Tree46Likes
Thread: Unimog Doka Project
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    Default Unimog Pakistan Fans Club
    Dedication:
    The dedications of an assignment is always coupled to the persons who are in point of fact involve in the hard work connected behind a victorious instrument which contains a universal interactions of such machine lovers and technical correlate, like for this piece of equipment under the lines has been done by a squad of Mr. Mubashar Sayyed, Mr. Mian Nadeem and Mr. Moazzam Sayyed.
    The audacious team members took an inventiveness to get reinstate the Doka in such a way someplace no examples has been established earlier in Pakistan and the financial plan, modus operandi and measurement has been used behind the thought were truly stimulating for me which leads to commence this new yarn.
    I am in no doubt that you guys will approximating this work and provide us a utterance of mouth to extend a in good physical shape discussion.
    Acknowledgment:
    Appreciation should Leeds to Unimog Punga and Deedee as pioneer in the Unimog restoration in Pakistan and purely hats off for their efforts.
    The Pioneers:
    Unimog Doka Project -454378
    Unimog:
    Unimog is a range of multi-purpose auto four wheel drive medium trucks produced by Mercedes-Benz, a division of Daimler AG. The name Unimog is pronounced [ˈuːnɪmɔk] in German and is an acronym for the German "UNIversal-MOtor-Gerät",Gerät being the German word for machine or device. Daimler Benz took over manufacture of the Unimog in 1951 and they are currently built in the Mercedes truck plant in Wörth am Rhein in Germany. Another Mercedes-Benz Türk A.Ş. plant assembles Unimogs in Aksaray, Turkey. Unimogs were also built in Argentina until the first years of the 1980s, in the González Catán factory. (Courtesy www. Mercedesbenz.com)
    Design
    Unimogs have very high ground clearance made possible by portal gears that allow the axles and transmission to be higher than the tires' centers. Unimogs also feature a flexibleframe that allows the tires a wide range of vertical movement to allow the truck to comfortably drive over extremely uneven terrain, even boulders of one metre in height. They are equipped with high visibility driving cabs to enable the operator to see the terrain and more easily manipulate mounted tools. The newest Unimog models can be changed from left-hand drive to right-hand drive in the field to permit operators to work on the more convenient side of the truck. The ability to operate on highways enables the Unimog to be returned to a home garage or yard to thwart vandalism.
    Specifications
    Unimog
    Introduced: 1955
    • Discontinued: 1980
    • Width: 2,130 millimetres (84 in)
    • Length: 4,900 mm (190 in)
    • Height: 2,190 millimetres (86 in), cab height: 1,600 millimetres (63 in)
    • Cargo bed: 3,000 by 2,000 mm (120 by 79 in), 2,130 by 2,080 mm (84 by 82 in) with double-cab
    • Wheelbase: 2,900 millimetres (110 in)
    • Turning radius: 13 metres (43 ft)
    • Empty weight: 2,900 kilograms (6,400 lb)
    • Gross weight: 4,400 kilograms (9,700 lb)
    • Cargo load: 1,500 kilograms (3,300 lb)
    • Tires:
      • 10.5 x 20 (DOT) ~37"x12.5R20
      • 12.5 x 20 (DOT) ~40"x12.5R20 (Courtesy Wikipedia)
    <o:p></o:p>
    Unimog Pakistan Fan Club
    Faheem Janjua
  2. #41
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    Quote Originally Posted by Sharo53 View Post
    ^^can you share its cost break down plz?
    for how much you bought it?
    expenditures on its engine, body, accessories, paint job, labours etc etc????
    Dear Sharo53, I am not directly in touch with those guys yet they are my friends and as I am not the part of restoration process done by them so I cannot give you details as required yet i can share their contacts with you where you can get in touch with Syed Brothers to get details and I hope they will give you.
    Moazzam Sayyed
    https://www.facebook.com/unimog.pakistan
  3. #42
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    یونی موگ کے بارے میں اپنے تجربات ضرور بیان کریں تا کے دوسرے لوگ بھی اس سے فائدہ اٹھا سکیں
    یونی موگ پاکستان لوورزکلب
    اکا ٹرک
  4. #43
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    اکا ٹرک
    Faheem Janjua
  5. #44
    azadjami's Avatar
    May 2008
    86
    126
    Fantastiicccc
  6. #45
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    اس پیغام کو شامل کرنے کا مقصد پاکستان میں چلنے والی تمام یونی موگ کے بارے میں گفتگو کرنا اور اس کو اچھے طریقے سے سامنے لانا تھا اور اس سلسلے کا براے راست یونی موگ رکھنے والوں سے کوی تعلق نہیں ہے
    مجھے خوشی ہو گے اگر لوگ اس کو دوسروں کو یونی موگ کے بارے میں اپنے تجربات بتانے میں استمال کریں
    منجانب
    پاکستان یونی موگ لوورز کلب
    Faheem Janjua
  7. #46
    pomi_pbs's Avatar
    Nov 2009
    878
    11 Post(s)
    7
    Quote Originally Posted by fouadar View Post
    so you left mutts/jeeps search, and joined unimog gang ?
    I am still in Mutt Search as always but no time to get it restore
    Faheem Janjua
