Page 11 of 54 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 1079
Like Tree171Likes
Thread: The Jeep Channel
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    What makes 4x4Engaged? special is to discover secret places others cannot reach! ✓
  2. #201
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow Misuse of the Clutch
    Engaging the clutch at the wrong moment either to change gear or to prevent a stall can create problems off-road. The beginner should avoid the clutch whenever the vehicle is traversing an obstacle – avoid changing gears and rather let the vehicle stall on a slope than risk a backward slide out of control. Next to hooliganism, misuse of the clutch causes more accidents off-road than anything else.
  3. #202
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow
    Permanent 4WD (Centre Differential Lock)
    Lock the centre differential if there is any danger that any of the vehicle’s wheels will lose traction and spin. Also as a safety measure when travelling at high speed on gravel or wet, oil-slick tar. Lock the centre diff whenever low range is engaged, no matter the
    conditions
    Super-Select’ 4WD (Mitsubishi)
    Engage four-wheel drive, centre diff unlocked in ALL conditions other than smooth dry tarmac. Locking the centre diff as above.
  4. #203
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Lightbulb
    Rear Axle Differential Lock
    Lock the rear axle differential in conditions which are severely undulating, when wheels lift well off the ground.
    Many off-road drivers tend to lock the rear diff the moment things become challenging. This robs them of a chance to learn and hone their skills. Just because wheels lift off the ground it doesn’t mean that a rear locker is needed. It just means that a rear locker will make it easier. Try your skills, use the push-pull technique and try and get through. If you find it is impossible or you feel that the vehicle is being stressed, go right ahead; stop the vehicle, engage rear diff lock and drive through. I recommend this approach because bad driving techniques are easily masked by a locked rear diff.
    In flat soft sand axle diff locks can hinder progress due to the under-steer they cause. This under-steer causes the turn of the front wheels being exaggerated creating a very high rolling resistance of the front wheels, halting progress. Always stop the vehicle before engaging. Failure to do so can wreck the differential.
  5. #204
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by raohamid View Post
    Objection! It was not dry pavement, it was dry kacha. I am proud of it. Now, coming back to you, please, don't dodge the initial comment, you want me to start showing videos?? I can guarantee I cannot find a video of you "Jacking up the vehicle, filling in the hole with soil, stones etc or covering it with a bridging ladder"!
    The way we do it at 4x4 Engaged? If car is not in 4Low, put it in. Give it gas, reverse, forward, reverse, forward, you will find you have dug deeper than what you imagined, trouble, call JRS (Janj Recovery Services), JRS will first come and say "Laalay, phir phass gaya hain", you will have to give that embarassing smile, then JRS will initate. First, two to three people will jump on the side skirts, bumpers, overhangs, start jumping around in unison, tell you to give it more gas, then you find the hole is bigger. Find tow strap, try to take out lightly at first, it won't work, tow-er will take a run up, driver of stuck vehicle will get a whiplash and neck ache, chassis or stuck vehicle will extend by 2 inches, and tow strap will break. Then you will take another tow strap, and try again, until the vehicle comes out.
    Do any of the 4x4 Engaged? members disagree? That's why we love going off road. The objective is not to do stuff easily, it is to get very stuck!
    And to the newbies, I'm just kidding. We're very careful
    RKR
    The Newbie is confused !
    "If YOU don't believe in what you're doing it'll never work."
  6. #205
    Sojourn's Avatar
    May 2007
    47
    363
    The suggested conversation in the 2nd paragraph of raohamid's comment is hillarious to say the least especially "lalay phir phans gaya hain"
  7. #206
    bugzy1's Avatar
    Mar 2006
    Riyadh
    35
    1,434
    Quote Originally Posted by SuhaibKiani View Post
    SK you should be the one least confused since your jeep has steel bumpers
    Bugged for Life....Easily Distracted by Land Rovers
  8. #207
    bugzy1's Avatar
    Mar 2006
    Riyadh
    35
    1,434
    Lightbulb
    @RKR
    yaar he uses this method to way pull out a stuck vehicle only for one reason - AWESOME VIDEO !!!!!
    reference
  9. #208
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    @Bugzy.... its a team work where Janj only making VDO ..... diff lock aka diggers did the job.....
    Still Play with Mogs... DeeMog 421.129 1986... http://www.youtube.com/user/DeeMog421
    http://www.pakwheels.com/forums/4x4-clubs-off-roaders-suv/87109-team-unimog-punga-project
  10. #209
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    one of the best VDOs by Mr. Janj.....
    @Janj.... can you put some light technique used in recovery????
  11. #210
    bugzy1's Avatar
    Mar 2006
    Riyadh
    35
    1,434
    Wink
    Quote Originally Posted by DeeDee View Post
    Light the stuck vehicle on fire !!!!!
  12. #211
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow Tyre Puncture
  13. #212
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow Driving on sand
  14. #213
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow Walking In Desert
  15. #214
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow Remember Never Leave your Vehicle
  16. #215
    DeeDee's Avatar
    Aug 2008
    Select City
    42
    6,029
    71 Post(s)
    4 Thread(s)
    Quote Originally Posted by Janj View Post
    now these are some good ideas but to apply all these we need to get to remote site.... why dont we plan something like crossing sahara....
  17. #216
    atherrr's Avatar
    Jun 2009
    Toronto
    24
    446
    Nice info>>
    Religion and Science are not at odds, Science is just too young to understand.
  18. #217
    bullseye's Avatar
    Oct 2010
    20
    you're the man. Keep the thread alive. Am looking for a good wrangler, let me know if you come across one.
  19. #218
    Janj's Avatar
    Apr 2008
    Select City
    44
    6,058
    39 Post(s)
    4 Thread(s)
    Arrow
    Quote Originally Posted by bullseye View Post
    Thx Jeep is always alive replied at your thread regarding wrangler.
  20. #219
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    RIP
  21. #220
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    RIP
Tags for this Thread
