Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By ajab9007
Thread: A/T Mode
    sbaluch's Avatar
    Feb 2009
    50
    58
    Default A/T Mode
    Guys, what does A/T Mode stand for in Intercooler. When I press that button, I can see PWR written against the 4WD layout. What does it mean & what is its purpose?
    ajab9007's Avatar
    Nov 2008
    Swatmingora
    25
    2,950
    16 Post(s)
    This switch, adjacent to the automatic shift lever, allows the driver to choose the gear range as appropriate.
    There are three positions, POWER, AUTO and HOLD.
    POWER: when switched on, the POWER light will show on the dash. In normal driving, with the shift lever in D, the power mode will operate through the full range of gears 1 to 3 plus overdrive when active. In 2, the power mode will only operate through 1 to 2, and in L, the power mode will only operate on the first gear.
    AUTO: In auto mode, the transmission will automatically change between POWER and ECONOMY modes as driving conditions define, changing to POWER mode for example when starting a hill ascent.
    HOLD: The HOLD light will show on the dash. The transmission will operate in ECONOMY mode through the full range of selected gears, not changing any higher than the selected gear, for example if you have selected L, the transmission will not change up to 2 or higher.
    Never go offroading alone!!!you never know when you need a push!!
    z06
    z06 is offline
    z06's Avatar
    Jan 2009
    30
    2,159
    2 Post(s)
    ^now thats knowledge (y)
    "Whoever said money can't buy happiness never bought a CORVETTE "
    ..::Z06::..
    sbaluch's Avatar
    Feb 2009
    50
    58
    Thanks a lot for this useful info ajab9007
