Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Like Tree7Likes
Thread: Land cruiser Auto gear getting very hot
    haroonkhan_01's Avatar
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    Default Land cruiser Auto gear getting very hot
    Hi Friends
    Recently I swapped my Land cruiser 92 London Model engine to 24 valve 1FZ-FE with Auto gear A442.
    Still mechanics are working on it. Today I go to a try and observed the gear lever and console is getting very hot with out AC. There is no warning light for A/T getting hot. Is it normal ?
    Please help me out before I accept the car and pay the money.
    I am trying to restore the car to a upper model like 97.
    Thanks
    Haroon
    ashbal's Avatar
    Sep 2006
    22
    2,056
    24 Post(s)
    i think it would be normal or the drive train would be touching the body....maybe the new gears produces more heat causing it to transfer to the gear lever....i dont think would be a problem
    M @ c!v!c '95 L0v3&
    ajab9007's Avatar
    Nov 2008
    Swatmingora
    25
    2,950
    16 Post(s)
    Check ATF
    Never go offroading alone!!!you never know when you need a push!!
    Haroon_Tarar's Avatar
    Mar 2008
    37
    3,213
    6
    178 Post(s)
    dats normal. it happens to almost every other diesel jeep
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    yeah. its normal with the new gear box. when i installed my new gearbox, i got the same problem. HEAT!! i taught its the heater core OR some engine air leakage entering the cabin, but NO, it was the gearbox issue. The whole area gets heated quite good enuff to feel after 1 hour of continuous drive, its when the gearbox comes in REAL-Warmup action!! Physics:Heat is energy. There is A-LOT energy there inside the gearbox, so it produces HEAT, especially new gearbox. the only 1 solution to avoid this issue is to double carpet OR aluminium foiled thick foam/fiberous coated sheet to the heating area of the whole gearbox in the passenger compartment, not the underbody. There is no such covering aftermarket or OEM solution for the underbody, which many mechanics will tell you to get the gearbox shield, that is useless term. This will need removal of front seats & the whole dashboard material, including other misc. plastics attached to the front area.
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    It's not normal. I have never had this kind of experience on any LC. Check if the gearbox cooling setup is properly working. Is the gearbox connected to separate oil cooler or radiator ? Was the car manual originally. ?
    Drive a Legend. Drive a Land Cruiser
    spitfire's Avatar
    Jan 2006
    53
    12,577
    62 Post(s)
    15 Thread(s)
    Quote Originally Posted by Saaduk View Post
    I agree ....its not normal .should check as per advice of @ Saaduk....
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    The car was originally manual and the gearbox is connected to Radiator. The radiator was changed also to petrol.Do I need to install a separate oil cooler. Can you tell me its price and if i can get it in rawalpindi. Thanks
    daudbros's Avatar
    Aug 2004
    51
    543
    6 Post(s)
    Dear check the Gear OIL.
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    Gear level is ok. Today I took it on a long drive and the gear lever got so hot that cannot touch the metal place on gear lever more than 5 sec.
    daudbros's Avatar
    Aug 2004
    51
    543
    6 Post(s)
    There is must be some load on gear!
  12. #12
    fouadhafeez's Avatar
    Feb 2008
    Rawalpindi
    50
    2,698
    7
    3 Thread(s)
    I agree with Saad: for the gear to be uncontrollably hot simply can NOT be normal. Common sense would dictate otherwise. I would suggest a little research on the subject. Does the 1FZ-FE (when mounted to a A442 transmission) come stock-fitted with an oil cooler? Are there any additional cooling arrangements for such a configuration? Are you using the right fluids? Are the gears fitted and engaged properly (on another forum, an FJ40 owner found out that the reason why he didn't have optimum speed was because he had inadvertently engaged 4L permanently)? Are all the electrical connections in order (electronics, being one area, where our maestros are somewhat less-than-entirely-reliable)?
    I think a combination of Google, and some good old-fashioned trouble-shooting should get you to some sort of logical answer.
    Best of luck.
    Always buy cars which your children love. They'll be helpful allies against your wife, later on!
  13. #13
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    I am trying to search for a 1996 LC with petrol to verify the fitting. Rest of the things are ok like pick and speed.
    If Any one having LC with the same engine 1FZ-FE with auto transmission Please tell me about the cooling system of transmission.
  14. #14
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    Quote Originally Posted by haroonkhan_01 View Post
    Your best bet is contacting Shabab Haider (Untame on PW), he has LC80 with 1FZ-FE and 4 speed auto-transmission. Mine is also the same but its LC100, so may have different setup. The other two 1FZ-FEs in IJC are with manual tranny.
    PS: it shouldn't get hot at all, console panel temp remians same as cabin temp.
  15. #15
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    @haroon
    ToyoDIY.com
    this is parts reference page for 1996 fzj80, you wil be able to find the exact arrangement here
    its all about power to weight ratio...
  16. #16
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    @nn Thanks very much for the input I will try to contact with Mr Shabab Haider
    @Ghuncha Very interesting website. Thanks
  17. #17
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    @nn Please can you tell me which type of silencer fits in FJ 80 LC with 1fz-fe. The local silence maker made it simple without the smaller two dholkis.
    And can we get these kind of silencer locally which fits bolt to bolt or minimum fabrication.
    http://www.toyodiy.com/parts/p_J_199...NPEK_1702.html
    http://www.toyodiy.com/parts/p_J_199...EK_1702.4.html
    Land cruiser Auto gear getting very hot -1048134Land cruiser Auto gear getting very hot -1048135
  18. #18
    nn
    nn is offline
    nn's Avatar
    May 2008
    12,094
    60 Post(s)
    3 Thread(s)
    I am no expert on these things, maybe a TLC 80 owner or some other expert will have to answer your querries here.
  19. #19
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    if you have access to the old radiator get hold of it re-route transmission cooling lines. Auto transmission is always connected to cooling system unless otherwise a separate oil cooler is part of stock set up
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  20. #20
    Mar 2009
    Rawalpindi
    37
    112
    2 Post(s)
    Old radiator is gone, but I am trying to change the radiator.
    Is it possible to check if the oil cooler is working fine before installing?
