Results 1 to 14 of 14
Like Tree10Likes
  • 1 Post By fuma
  • 3 Post By desertdevil
  • 1 Post By joinami
  • 1 Post By lateralus
  • 2 Post By lateralus
  • 1 Post By joinami
  • 1 Post By joinami
Thread: 6G72 DOHC in Gen1 Pajero (SWB).....Is it possible?
    gurk's Avatar
    Sep 2011
    others
    37
    13
    Default 6G72 DOHC in Gen1 Pajero (SWB).....Is it possible?
    My Pajero is currently powered by 4D56 turbo inter-cooler version of engine (all stock).
    My questions:
    1: Can I swap 6G72 DOHC (engine is probably from a mitsubishi GTO car) in my Gen1 Pajero? offcourse I mean is it bolt on and without any major modifications in engine foundations and mounts etc?.
    2: does this engine couple with existing gearbox or any modification in bellhousing or in anyother thing will be required?
    3: I have seen Pajeros with 6g72 SOHC and that engine looks quite different in appearance; is there any major difference in DOHC version other than head?
    4: Yes, I know alterations in air intake, exhaust, radiator etc will required under the bonnet...is there anyother thing which is not doable?
    5: and anyother thing which; I may have missed
    As I am not interested in major modifications, weldings and cuttings; re-building 4D56 is always an option.
    Kindly help by your inputs
    regards,
    gurk's Avatar
    Sep 2011
    others
    37
    13
    No Pajero experts?
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    The 4D56 is BRILLIANTLY ENGINEERED A-Class Super Small Diesel Engine i've ever seen in large size SUV's like PAJERO!!
    My advice: Don't CHANGE 4D56. Swap your old gearbox to new one, cause 4d56 need new gearbox after every 200k miles.
    You just need to TUNE-it accordingly & perfectly to get the maximum efficient performance.
    Good: Excellent mileage / Bad: under/slow/sluggish acceleration.
    You need to analyze & balance all the parts to work correctly & perfectly, including back pressure/exhausts/turbo & manifold setup/intercooler setup(check air leakage or blockage) etc etc. All these things need to be adjusted appropriately to get the best from 4d56. Enjoy!
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    gurk's Avatar
    Sep 2011
    others
    37
    13
    Thanks fuma!
    I do reckon that a Properly tuned 4d56 is good. Gearbox is working fine and no issue has been faced or observed.
    But my questions regarding 6G72 DOHC swap are still not answered?
    Anyone there?
    taskheershamas's Avatar
    Mar 2011
    222
    I think IT is do able and the gear box also support this engine. the bad part of 1st Gen pajero is that it have almost one piece gear box while toyota use removable Bell housing mostly which helps in swap.*
    *i think you wait for the Mitsubishi experts like Mitsuman ,joinami,laparwah etc..............
    desertdevil's Avatar
    Dec 2008
    45
    2,542
    30 Post(s)
    you can put a 6G72 sohc in gen 1 but not a dohc version without a major surgery. Sohc will sit bolt on. It has about 150 horses to it. The DOHC version came in Gen 2 and is a bit more powerful but they would sit bolt on in a 2.8 pajero i think. i would suggest go for SOHC version, it has lots of power and you will enjoy it. Advisable would be to get it off a half cut to avoid missing links etc.
    gurk's Avatar
    Sep 2011
    others
    37
    13
    My 4D56 TDi was sluggish, powerless and blowing a lot of black smoke. As I have been maintaining it. I knew that the engine was fine but the local mechanics were saying that the engine is getting weak. I searched and contacted few experts from Pajero forums....and acted upon their advices:
    1: Gave the whole air intake path a thorough cleaning and changed the air filter.
    2: Checked and adjusted Tappets
    3: Blocked the EGR valve
    4: Checked the turbo waste gate actuator. Waste-gate was not permanently open and working properly.
    Believe me it has made a lot of difference. My Pajero is much better, responsive, quick and powerful now and no black smoke at all. Hearing the turbo spooling and giving full boost is much fun now.
    Note: Don't just listen to the mechanics; they may mislead you.
    But the questions regarding 6g72 DOHC swap are still open please!
    Regards,
    Sohaib
    waqasch1's Avatar
    Mar 2006
    Dubai
    288
    9 Post(s)
    4 Thread(s)
    Quote Originally Posted by gurk View Post
    Regards,
    Sohaib
    Looking for a capable Pajero Diesel Mechanic to rebuild 4D56TDi, any help possible?
    Where did you get the above done, DIY or Mechanic?
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Quote Originally Posted by waqasch1 View Post
    do let me know too if u find one....
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    Dear u do nt need a mechanic...
    Quote Originally Posted by joinami View Post
    From 2.0 Toyota Corolla to 2.5 MMC Pajero ...Corolla u ll always b missed...but the life goes ON...
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    Dear if my ustaaad e mohtaram had time v would have overhauled your engine ourself...but unfortunately he s bz these days...
  12. #12
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Quote Originally Posted by lateralus View Post
    Now this is Flattering ,,,,,adnan Bro...
    Old is Gold
  13. #13
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    if u have time lets overhaul it ...what do u say...v can overhaul it either in lahore or isloo
  14. #14
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    no time dear . busy busy busy to each and every second.....for few days
    Old is Gold
