Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By devils_smile
  • 1 Post By AmeerUsman
Thread: how to use 2006 Vigo 4x4?
    MyVigo's Avatar
    Oct 2012
    Default how to use 2006 Vigo 4x4?
    Hi guyz!
    I just bought a vigo and its my first 4x4 and i need to know several things:
    1. Which gear to drive in when im driving in city?
    2. Which direction the gear stays in because its missing the 4x4 gear knob?
    Your help will be much appreciated!
    Thanks
    devils_smile's Avatar
    Feb 2009
    Bonn
    26
    4,584
    171 Post(s)
    6 Thread(s)
    ok there are three options in 4x4 mode. 2WD, 4WD(high), 4WD(LOW).
    2wd: Normal driving (city, highway and even rough terrain softroading)
    4wd(high): Slippery conditions, steep hills and climbs. Basically for better traction. all 4 wheels are driving and ur car will still be running like in 2wd though fuel consumption may increase.
    4wd(low): Heavy offroading. pulling heavy cargo. rough terrains. if ur stuck
    heres the general layout of the 4wd gear. down (2wd), slide it up (neutral), slide it to the right(4wd high), slide it up(4wd low). Its better u engage ur main gear to neutral, switch to the desired 4wd option and then change gears. same goes for diengaing the 4wd gear. the 4wd can also be engaged when the vehical is moving at low speed but its better u stop the car.
    My 1985 Mercedes Benz W201 190D (DIY's, Detailing and Photo-shoots)
    http://www.pakwheels.com/forums/members-member-rides/207432-my-mercedes-c-class-w201
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    In city driving 2L mode which in Vigo is toward left side and forward ( as is 1st gear position).
    MyVigo's Avatar
    Oct 2012
    Thanks Devils_smile!!
    You really made it easy to understand except the layout part hehe
    MyVigo's Avatar
    Oct 2012
    thanks AmeerUsman!
    can u tell me the other gear positions as well (i.e 4WD High and 4WD Low)
    thanks
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Actually I dont have my own Vigo but I use to drive my Office (GOVT) Vigo. So dont rememeber much but I think when u slide it back from 2H then its 4H. From here push toward right and then forward, it is Neutral and then move it forward once again so it is 4L. And please note that Im talking about Pakistan assembled Vigo, so please wait for more replies of expert. U can also watch 4wd Indication inside ur dashboard panel, whenever 4x4 is engaged.
    MyVigo's Avatar
    Oct 2012
    thanks!!!
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    The Vigo must have come with a User / Owner's manual ? or you purchased it used 2nd hand ? - Ask raza1 for user/owner's manual for the Hilux 4x4 he will email to you. Good Luck
    Quote Originally Posted by MyVigo View Post
    Hi guyz!
    Thanks
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Feb 2009
    Bonn
    26
    4,584
    171 Post(s)
    6 Thread(s)
    http://images.esellerpro.com/2133/I/...ear%20knob.JPG
    here this is the shift positions of a toyota vigo
