Results 1 to 4 of 4
Thread: Synthetic OR Conventional OIL in OLD Diesel Engines ?
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Question Synthetic OR Conventional OIL in OLD Diesel Engines ?
    What should be used for Best Engine LIFE / Performance / Fuel Economy
    some good & ugly FACTS:
    CONVENTIONAL: Temperature resistance upto 150 C
    Conventional / Mineral oils are based on petroleum oil which is refined from crude oil. They have chemically weak properties and deteriorate soon during normal engine operation.
    But, they don't eat engine seals,gasket & other related similar objects.
    Conventional oil is slightly more viscous than synthetic, which makes it more effective in protecting an engine.
    But are not powerful/flexible to handle extreme HOT or COLD temperatures.
    & contains contaminants, which may build-up sludge during extreme HOT temperatures.
    SYNTHETIC: Temperature resistance upto 250 C
    History: (Synthetic motor oil is made through a chemical process that was discovered in Germany during World War II when crude oil was limited.)
    Synthetic oil is an artificially produced lubricant. It performs better at extreme temperatures and produces longer engine life.
    Synthetic oils are refined and produced from stronger chemicals that can keep their properties for longer during normal and severe engine operation, hence long drain intervals compared to mineral/conventional oils.
    But due to large scale of chemicals, they eat up engine seals, gasket, start small leaks & can't switch back to conventional oil once used.
    However, Synthetic oil doesn't lose its ability to flow well in cold weather, so it is preferred for cars driven in cold climates.
    When synthetic motor oil is used over time, it can dissolve sludge and deposits in a vehicle's engine that have been left behind by conventional motor oil.
    Synthetic oil is Thinner than conventional/mineral based oil, decreasing the oil pressure in the engine, but flowing more easily/rapidly on the engine startup.
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    bump! bump!
    Qaisrani's Avatar
    Dec 2005
    Other
    3,910
    6 Post(s)
    For old Engines, Conventional OIL is the best choice.
    I don,t believe in taking right decisions, i take decisions and make them right !
    asadsethi's Avatar
    Jul 2008
    Peshawar
    37
    1,990
    13 Post(s)
    2 Thread(s)
    Good info, thanks
    Founder, FRONTIER 4X4 CLUB : Adventure begins where road ends!
Tags for this Thread
