Results 1 to 9 of 9
Thread: Transmission advice for Rocky with Toyota 2L
    RovingCalypso's Avatar
    Apr 2006
    30
    82
    Default Transmission advice for Rocky with Toyota 2L
    Hello there Brothers
    As the topic says, I intend to replace the gearbox of my rocky. It has a Toyota 2L engine with a Rocky 5 speed manual gearbox with transfer, dont know which model.
    I changed it a couple of years ago, it originally had a 4 speed manual with transfer. After the modification, it developed this weird vibration+noise in only the fifth gear, even at the same speed of, say, the 4th gear.
    Secondly, the ratios are tight and I am using it almost exclusively within city. 120 kph on the motorway and the engine screams.
    So I am looking for a gearbox which can give me a decent run within the city and should be alright even on the motorway at 110/120 kph.
    Kindly advice on both with and without the 4wd options. If anyone can quote the price and availability, that would be awesome.
    Thanks
    Similar Threads:
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    You can probably look into slightly simpler solutions (1) changing gear set of ring-pinions to a taller/longer ratio (2) changing gear set (garraris) in the gear box with longer/taller set....
    The Rocky machinery has a bit of variation over the years and you should be clear on what ratios you are currently running as there is probably either a longer/taller ring-pinion and/or garraris sets available....
    All the best!
    "If YOU don't believe in what you're doing it'll never work."
    Apr 2006
    30
    82
    Hmm, well I could look into that but I think the gearbox has some mechanical issues as well especially in the 5th gear with that weird noise.
    Can you recommend me a good mechanic in Lahore for this?
    And which gearbox do you recommend (both with and without 4wd, manual 5-speed) if I go for a swap?
    Thanks alot
    Apr 2006
    30
    82
    Thanks alot
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    23 Thread(s)
    This gearbox develops vibration and noise over time and there is no fix for it as such. Suhaib is right, play with it to get desired ratios.
    Keep a cool head and wear seatbelts!
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    You should stick to Rocky gearbox to avoid modifications, try to find one with longer gears otherwise change diff ratios too by swapping ring/pinion set...
    fahadmiester's Avatar
    May 2005
    Peshawar
    30
    1,474
    3 Thread(s)
    you can put in an auto gearbox of prado, that will be better for cruising on the motorway but it will drink more fuel
    no comments
    VigoCHAMP's Avatar
    Apr 2012
    75
    change your diff ratio, put a higher set and you will feel the difference on motorway.
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    what do you mean by higher ratio... i m also having a rocky .. firstly 4 forward gear box.. now with its original 5 forward gear box.. with 2L turbo.. having 11/37 differentials ... which differentials have the higher ratio.. 11/37... 10/37.. or 9/37..
