Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By Rizvi79
  • 4 Post By SuhaibKiani
Thread: Toyota Hilux 1987 - Engine Swap Advice PLEASE??
    Rizvi79's Avatar
    Feb 2011
    11
    Default Toyota Hilux 1987 - Engine Swap Advice PLEASE??
    Hello!
    I am using the following vehicle under daily drive category. Would like some advice on an engine swap? Its currently on 1kz with an auto transmission. Basically all parts under the hood are from a 1999 surf which was bought from shershah and transferred including braking system (4 disc brakes) and differentials.
    Which petrol engine will be suitable for a good drive? (not losing the thrust of the 1kz) Anything over 6 or 7 is good.
    Thank you for your valuable input in advance!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    5VZ 3400cc V6 comes to mind....
    "If YOU don't believe in what you're doing it'll never work."
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    Suhaib bhae absolutely right ...
    Also I think that 3RZ 2700.cc will run great if in manual transmission
    VigoCHAMP's Avatar
    Apr 2012
    75
    @Rizvi79 How come you have a 4 disc brakes system? if iam not wrong 99 surf comes with a rear drum and front disc
    Or you have converted those drums to disc?
    VigoCHAMP's Avatar
    Apr 2012
    75
    3RZ or 5VZ both will run good on your vehicle.
