Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By fuma
Thread: PCV Valve Outlet Removal benefits
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Exclamation PCV Valve Outlet Removal benefits
    Who has removed PCV Valve's outlet from the intake zone to Free-Air zone? The Road Draft Tube - Old method.
    Share your experience & removal/conversion to road draft benefits of crankcase ventilation.
    Ventilated Crankcase helps extending the life of engine by preventing the buildup of sludge in the oil and by keeping water/moisture out of the engine, preventing corrosion from appearing in the engine, therefore TOTAL removal of the whole PCV Valve Or blocking the ventilation hole/valve cover is not at all suggested. But only a little modification is needed to make it much better, that is the old road draft tube method.
    Road Draft Tube method pollutes the environment no doubt, but instead of sending gasses to the intake & chamber, why not send them outside. As there are no emissions Law in Pakistan, one can benefit from Road Draft Tube methodology
    Enjoy!
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    orange17's Avatar
    Jan 2010
    Rawalpindi
    28
    923
    19 Post(s)
    3 Thread(s)
    I don't know what it is ?
    Please elaborate,
    & how can I do it to my Toyota L.C 1992 ( 80 Series ) ?
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,307
    49 Post(s)
    You mean open the valve in free air and close the port on the manifold?
Tags for this Thread
