Results 1 to 16 of 16
Like Tree11Likes
  • 1 Post By atharshah
  • 2 Post By TLCFJ40
  • 3 Post By SuhaibKiani
  • 1 Post By ShaMaaL
  • 1 Post By Saaduk
  • 3 Post By hash4u
Thread: 2JZ-GE in FJ40
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Default 2JZ-GE in FJ40
    Dear All.
    Require input/suggestion/advice from experts regarding installing 2JZ-GE in FJ40 1984 model.
    Current set up is 2F with four forward gear.
    Thanks in advance.
    Site Banned Follow
    atharshah's Avatar
    Feb 2012
    1,640
    20 Post(s)
    2 Thread(s)
    whats the point..........u know the history of 2jzs into suvs in pakistan. it is not pleasing
    suvs are low centre of gravity vehicles
    & 2jz is a hi thrust engines
    u are like trying to hit 2 opposite poles of the magnet to each other
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    Quote Originally Posted by atharshah View Post
    They're actaully HIGH center of gravity vehicles and the engine in question is a 2JZ-GE and not a GTE which is fairly less powerful than a GTE and wouldnt be too bad of an option.
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    but whats the point if high speed then yes with gear swap if economy then both are the same
    off roading not much help ful
    exmple 2f is like diesel engine and 2jz is petrol
    means 2f is more powerful at 1500 rpm and 2jz works on 4000rpm
    higher reving engine
    so again whats the point is why u want to swap
    Mohsin Rana
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Actually a fellow advised on swaping 2JZ-GE.
    I didn't have any info/idea so posted the thread for better understanding.
    Comments/suggestions are welcome.
    Thanx.
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    if the primary usage of your j40 is offroading then the only solution is diesel and diesel only.
    <<<The Obstacle Is The Path>>>
    1984 BJ41, 1967 FJ40, 1984 BJ61 , 1983 Mutt M825, 1982 CJ5, 1942 Willys
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Quote Originally Posted by machine View Post
    Only Off Roading is not the objective.
    It has to be used for local driving at times.
    TLCFJ40's Avatar
    Sep 2006
    37
    1,784
    7 Post(s)
    Brother life is precious cherish it. Figure out what u need your fj40 for and than decide. BUt which ever way u want to go forget about high reving engine they turn fj40 in to a death trap. Popular options are 1kz/b2/b13-t in diesel.
    Toyota All The Way !!!!!!!!!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    I would think the 2JZ-GE (not the turbo charged GTE!) in an FJ40 should be fine enough if you mate it to the original gearbox and diffs. Plenty of 2JZ conversions in CJ7s/CJ5s by now though not many perhaps in FJ40s because of various reasons. Fuel economy is a good reason of swapping 2F with 2JZ even though its not the best match for the drivetrain...
    The FJ40 gears and axles are quite heavy and bulky and though it will be a very fast car, it will not be tremendously overpowered. On the contrary, the heavy drivetrain would put the 2JZ to a challenge and life expectancy of the engine and parts may not be comparable to a slightly bigger engine. 4 wheel disk brakes and 31 inch tires with wide/backspaced rim would be a must!
    "If YOU don't believe in what you're doing it'll never work."
    ShaMaaL's Avatar
    Jan 2012
    319
    4 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Well, this is a comprehensive answer addressing pros and cons of swaping engine in question.
    Thanks SuhaibKiani.
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    2jzge is a bad choice. Go for 5vz instead or anything which is designed for SUV applications.
    Drive a Legend. Drive a Land Cruiser
  12. #12
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    406 Post(s)
    13 Thread(s)
    13
    people want cygnus v8 engines in cars
    and sports car engines in jeeps
    it seems we are smarter then the Japanese
    LoL
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    the 2JZ-GE needs to be revved a bit to make any usable torque. Unless you have super low gears I see it as a liability as it weighs a lot too.
  14. #14
    mad_racer's Avatar
    Mar 2006
    30
    2,598
    3 Post(s)
    Default 2JZGE in FJ40
    2JZGE isnt that powerful when compared with the GTE version.
    I have swapped my CJ5 with a 2JZ-GE and honestly it's not a death trap at all. The vehicle is extremely quite on idle.
    Diesel noise irritated me alot. I have decent power not something that would kill me unless my time is up. Mated it to an auto tranny along with 4x4 resulting in a decent daily driver and off-roader. I would suggest you to go for it.
    Work in Progress: Nissan Skyline R-31
  15. #15
    Proverbial_Slang's Avatar
    May 2005
    3,904
    29 Post(s)
    Quote Originally Posted by mad_racer View Post
    What is your approx quarter mile time (for assessment of acceleration purposes only) and approx RPM at 120 Km/H?
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  16. #16
    mad_racer's Avatar
    Mar 2006
    30
    2,598
    3 Post(s)
    Quote Originally Posted by Proverbial_Slang View Post
    Never checked. Been working on another project lately. The CJ has been parked after the swap hardly driven 500km on the 2JZ.
