Page 1 of 15 12311 ... LastLast
Results 1 to 20 of 296
Like Tree231Likes
Thread: V8 FJ40 Restoration Project | www.4x4MeanMachines.com
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Thumbs up V8 FJ40 Restoration Project | www.4x4MeanMachines.com
    A parallel project which was long awaited and finally comes to its startup point. I was able to get hold of a nice piece during my restro search of 4x4s.
    The reborn of this FJ would be entirely for offroad purpose so we have planned to put all stuff accordingly. Since so many minds are working on this so I expect to have a masterpiece ready in the end & all types of suggestions are welcomed.
    Initially we have planned to take a start from suspension includes, new diffs, 4 wheel disc, front hub locks, front and rear e-lockers, new shackles and some refurbishment to kamanies.
    Then we will move on engine 1UZ with 5 forward gearbox, upper model power steering, brakes, new shafts, double silencers and misc. and then the tire department
    After having test rides paint job, interior and exterior decorations will be started, a wonderful and powerful winch is also anxiously waiting to sit on this FJ first.
    Rest pics will say all… stay tuned!
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121011
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121012
    GO MEAN OR GO HOME | facebook.com/4x4MeanMachines | facebook.com/ythband
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Bahtreen Bro so is it 1UZ or 2?
    <<<The Obstacle Is The Path>>>
    1984 BJ41, 1967 FJ40, 1984 BJ61 , 1983 Mutt M825, 1982 CJ5, 1942 Willys
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by machine View Post
    Machine,
    Plans were to install 2UZ but now we are going for 1UZ.
    Anyone where can explain pros and cons of 1UZ OBD-1 and OBD-2 ?
    Rgds.
    FDAR
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    The 1UZ has two primary versions the more common pre 95 OBD I:
    V8 FJ40 Restoration Project | www.4x4MeanMachines.com - 1870203145 1UZ FE
    .....and post 95 OBDII VVTI one which looks more like the 2UZ:
    V8 FJ40 Restoration Project | www.4x4MeanMachines.com - T2eC16RHJHQE9nzEzNWyBQCYnGlpgg60 35
    The newer VVTI has an electronic accelerator pedal (drive by wire) which can be a pain to match up unless you have a matching accelerator assembly, nevertheless its doable albeit will cost 20k extra. Most of these engines also have a immobilizer which needs to be unlocked for another 15k or something. The con of the older engine is that its slightly difficult to find a clean one in Pakistan, nevertheless the part availability is there to a large extent....
    Whichever version you get make sure that you get a deal with the kabaria in the sense that he will guarantee to replace/provide any parts that you may need even if you have to pay more upfront. Some parts which can be problematic on older engines are Air Flow Sensor (AFM), wiring connectors, ECU, AC compressor and power steering pump.....
    Most importantly make sure that the wiring for any engine you get is as much "there" as possible. On older models there are a number of variants and you should please make sure that (i) Wiring (ii) AFM and (iii) ECU are from the same engine model otherwise it can be a major issue.....
    All the best for the build! Let us know if you need any help!
    "If YOU don't believe in what you're doing it'll never work."
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    SK,
    Thanks a lot you have solved my big problem, before this i have heard 100 stories about OBD-I and OBD-II, bla bla bla.
    I think i will go for OBD-I, reason dont wana spend some extra thousands and i think this one will easily go along with our local ustads.
    Visit BG yesterday and i found 100s of 1uzees out there in perfect and complete condition.,
    Next week have plans to go for final shopping for engine and gear.
    At present i am working on e-locker diffs and expected to have them ready from workshop by tmr noon.
    Once suspension is ready will put in the engine and gear.
    Any sugguestions during this process are welcomed.
    p.s pls check your inbox and reply me for adaptor plate.
    mfdarvesh's Avatar
    Jul 2007
    2,807
    30 Post(s)
    Good Luck Brother
    Do inform us about updates on this Jeep
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by mfdarvesh View Post
    Good Luck Brother
    everything related to this project will be posted here.
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Visit to Bilal Gunj for misc shopping.
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121889
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    You can find anything there!
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121891
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Some engine pics from BG market of Lahore!
    There is a hidden project going on as well so need some bigger engines as well.
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121908
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121909
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121910
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1121911
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Reached Rwp for some LC shopping, need to reach Kala Khan famous for kabli gears (learnt this from BG shopkepers) some where around Mithu area, dont know the exact name of place.
    1st thing i need is 5 forward LC gearbox (kabli) and a hardtop (heard i can easily get one from city sadar road)
  12. #12
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by fouadar View Post
    You can get the hardtop from Gulzar Ustad or Jamil Ustad at Citi Sadar Road. You should be able to get a clean FJ40/FJ60/FJ70 5 speed gearbox from various people in Rawalpindi. Will PM you my number if you don't have it, let me know if you needany help.
  13. #13
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Will call you tmr for gears. tks.
  14. #14
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    while you are at city saddar.. get a snorkel too from Jamil ustaad.. its a must have these days for all J40s
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  15. #15
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by akifjanjua View Post
    Thank you Akif, i visited after reading your msg and bought one from Jamil ustad
  16. #16
    xdefender's Avatar
    Feb 2010
    Rawalpindi
    43
    9
    Kala khan's shop is in ASTABAL # 2 and its near kashmiri bazar .
  17. #17
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by xdefender View Post
    Thanks but unfortunately i could not visit this guy, but i think now i have my hands on the right guy who deals in pure kabli maal.
  18. #18
    isiddique's Avatar
    May 2006
    Jehlum
    44
    282
    Fouadar I am assuming you have visited BG lahore market for engines and parts recently. Who would you recommend for 1KZ-T and 5 Speed manual gear box in Lahore? I am looking this setup for my FJ40, 1982. It has 2F with 4 speed currently.
    If you could please pm me their number.
    Regards,
    God grant me the serenity to accept the things I cannot change, courage to change the things I can, and the wisdom to know the difference.
  19. #19
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Quote Originally Posted by isiddique View Post
    Regards,
    Dear we usually buy engines from ch. Shafaqat, I will pm you his numbers.
    Secondly we buy gears from a molvi sb who deals in only kalbi gears you can also ask for him when you are in BG.
    He shop is in basement.
  20. #20
    fouadar's Avatar
    Jun 2009
    3,473
    27 Post(s)
    Default Baby sits around in workshop while ustaad ji is working.....
    V8 FJ40 Restoration Project  www4x4MeanMachinescom -1137476
