Page 25 of 29 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 570
Like Tree369Likes
Thread: The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    Toyota Hilux LN65 - 1UZ-FE V8 Transplant:
    Project HiLex Kaikra Build! -1221618
    Mitsubishi Pajero Evolution - 2JZ GTE Twin Turbo Transplant:
    Project HiLex Kaikra Build! -1221617
    Owner: Qasim Saidhi
    Builders: Awan Brothers, Citi Sadar Road, Rawalpindi
    Advisors: Too many....
    Current Status: Read on and wish us luck....
    "If YOU don't believe in what you're doing it'll never work."
  2. #481
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Body removed, Suspension removed, Diffs removed
  3. #482
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Work in Process
  4. #483
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Chassis scrubbed/cleaned, revealing a lot of unwanted rust
  5. #484
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Chassis moved to the workshop, damage assessed, measurements taken.
    Noted that both front shock towers had cracks, they were bent to the inside and the chassis on the left was bent upwards
  6. #485
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Meanwhile, the body shell at home
  7. #486
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Chassis and Shock Towers being pushed back to their genuine positions
  8. #487
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Measurements
  9. #488
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Shock Towers reinforced yet again
  10. #489
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    While transplanting 2JZ, Farooq sahib in Rawalpindi had shaved the oil pan, yet, it was rubbing the front fixed diff, so moving the engine further back was a necessity.
    New mounts for 2JZ engine, which will move it back by 5.7 inchs, were temporarily installed after cutting the portion of mounts of auxiliary shocks. Plan is to place the 2JZ on the new mounts once the front diff is installed, if the oil sump of 2JZ is clear of the diff, these new engine mounts will be properly welded otherwise we will move the mounts further back
  11. #490
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    5.7 inches back,,, firewall will surely be operated
  12. #491
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Chassis/Shock Towers straightened and strengthened, time to rub the rust off for a new paint job
  13. #492
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by saidhi View Post
    Do check the rear shaft length to make sure it has room to accommodate 5.7 inches....
  14. #493
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Can't see the pics but if the frame is open then why not reinforce it once and for all. Ideally the roll cage should also be bolted onto it to add more rigidity. We now know for sure that stiffer is better for racing, on or off road.
  15. #494
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    I think it will,,, but in case it doesn't, we will stretch the frame
  16. #495
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Frame already strengthened from weak areas.
    Since the gear is going back almost 10 inches in total, driver seat needs to be back as well, therefore the roll cage has to be be redesigned. Insha Allah, we will put a proper FIA spec roll cage
  17. #496
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Chassis arrived from paint shop
  18. #497
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Time to check and clean all bushes, arms, hubs, boots, disks, their rotors etc
    All 3 bushes holding the front diff broken, two of the 8 axle boots need to be changed, front hubs have a little more play than normal, 1 of the 4 arms holding each of the rear wheels need to be changed, rest all in perfect condition.
    To be on the safer side, decided to put all 4 caliper kits
  19. #498
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Evo's pull type performance clutch and pressure plate was available but Rashid Abdullah, who is one of the technical advisers of this project, told to stay away from pull type clutches because they are always prone to malfunction. Have personally witnessed Muhammad Ashraf and Zafar Magsi out of rally/DNF on more than one occasion because of this clutch problem, so, pull type clutch is to be changed with a push type clutch.
    Plan to go to Bilal Gunj tomorrow and see which housing of push type Pajero gear is similar to Evo's gear housing. Have been told that the gear housing of the manual gear of Gen-II with 4M40 is similar to Evo's gear housing and that gear is a push type, so,, fingers crossed. Otherwise will order the kit from Thailand.
  20. #499
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Its been about a month or so and i saw the Evo sitting in the corner quietly. But gotta hand it to you, you've stripped it apart and have started to put it back in already in that period of time.
  21. #500
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Firstly, what I was suggesting was to re enforce the entire frame like done on the Nissan. Desi terminology would be to double the frame as is done on loading FJ40s and Hiluxes using an extra plating of metal on top/bottom of the frame. The weak area strengthening is a basic job but we know what this frame is going to be put through and the more rigid it is the better. Nevertheless, if it's already back it's OK I guess, because your gonna be opening it up next year again probably to fix bends etc
    On the whole, even I am taken aback with the magnitude of mods you are outlining as it is a far cry from the minimal modification attitude with which you started off. Not that I am complaining or discouraging
    Good to know that the roll cage will be redone properly, wonderful news actually. Would recommend that you should look into tying the base of A and C pillars to the frame as it would help the car take a lot more abuse by stopping frame flex. May also help the handling generally though difficult to say anything on that department as yet.
    All the best. Keep up the good work and keep us posted.
