Page 26 of 29 FirstFirst ... 162425262728 ... LastLast
Results 501 to 520 of 570
Like Tree369Likes
Thread: The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    Toyota Hilux LN65 - 1UZ-FE V8 Transplant:
    Project HiLex Kaikra Build! -1221618
    Mitsubishi Pajero Evolution - 2JZ GTE Twin Turbo Transplant:
    Project HiLex Kaikra Build! -1221617
    Owner: Qasim Saidhi
    Builders: Awan Brothers, Citi Sadar Road, Rawalpindi
    Advisors: Too many....
    Current Status: Read on and wish us luck....
    "If YOU don't believe in what you're doing it'll never work."
  2. #501
    N2O
    N2O is offline
    N2O's Avatar
    Nov 2005
    2,317
    15 Post(s)
    great project!! keep it up
    knowledge is horsepower
  3. #502
    thetigerzzz's Avatar
    Jan 2013
    37
    1,160
    31 Post(s)
    good going sir zabardast
  4. #503
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Firstly, what I was suggesting was to re enforce the entire frame like done on the Nissan. Desi terminology would be to double the frame as is done on loading FJ40s and Hiluxes using an extra plating of metal on top/bottom of the frame. The weak area strengthening is a basic job but we know what this frame is going to be put through and the more rigid it is the better. Nevertheless, if it's already back it's OK I guess, because your gonna be opening it up next year again probably to fix bends etc
    On the whole, even I am taken aback with the magnitude of mods you are outlining as it is a far cry from the minimal modification attitude with which you started off. Not that I am complaining or discouraging
    Good to know that the roll cage will be redone properly, wonderful news actually. Would recommend that you should look into tying the base of A and C pillars to the frame as it would help the car take a lot more abuse by stopping frame flex. May also help the handling generally though difficult to say anything on that department as yet.
    All the best. Keep up the good work and keep us posted.
    3 years of rally abuse and there is not a millimeter of extra bend at the back. Vulnerable areas are the front shock towers, which go inwards and the bends/portion of the chassis from shock towers till the fire wall, which goes upwards. These areas have been strengthened with a 10 mm steel sheet, may be they will bend again,,, may be not,,, but in any case, there is no point in adding minimum 25 or 30 kgs of steel at the rear section where there is no chance of bending.
    Nissan's frame was also strengthened till the middle of the front doors only.
    The idea of replacing temperamental Pull Type Clutch with a more dependable Push Type Clutch has been scrapped for the time being,,, very long story but all the Gurus including Rashid Abdullah and Yasir Ghani were of the opinion that we do not have much option here,,, so Evo's genuine Gear Box with Pull Type Clutch Setup is staying.
    Only desired modification was to have a 2JZ,,, rest are all consequential modifications. No stone will remain un-turned to make this a rally monster. I am lucky to have all the necessary technical help, project has basically a blank cheque, full time mechanic working in my porch,,, lets keep the fingers crossed, Insha Allah it should turn out to be a winner.
  5. #504
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Turned out that 5 out of 8 axle boots needed to be changed, broken bushes changed too
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1442927
  6. #505
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Evo's OEM size is 265/70-16 but for Jhal and Nooriabad I used MTs in 245/75-16.
    For the turbo powered Evo, wanted to have MTs in the OEM size, but none were available, so, today, ordered six of the the following in 265/75-16. Insha Allah, these will be delivered by the middle of September
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1442930
  7. #506
    salmanzahid's Avatar
    Jul 2014
    145
    3 Post(s)
    @saidhi sir very nice
  8. #507
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    We started putting the Evo together on 21st July
    Front and Rear Diffs first, then the assembly of all 4 wheels
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456424
  9. #508
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456425
  10. #509
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456426
  11. #510
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456427
  12. #511
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456428
  13. #512
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456429
  14. #513
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456430
  15. #514
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456431
  16. #515
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456432
  17. #516
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    This is how it was left for Eid
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456433
  18. #517
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456434
  19. #518
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Work restarted on 4th August
    Engine and Gear was re-mated, new Stage 1 Clutch and Pressure Plate in
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456435
  20. #519
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456436
  21. #520
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456437
