Page 27 of 29 FirstFirst ... 172526272829 LastLast
Results 521 to 540 of 570
Like Tree369Likes
Thread: The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    Toyota Hilux LN65 - 1UZ-FE V8 Transplant:
    Project HiLex Kaikra Build! -1221618
    Mitsubishi Pajero Evolution - 2JZ GTE Twin Turbo Transplant:
    Project HiLex Kaikra Build! -1221617
    Owner: Qasim Saidhi
    Builders: Awan Brothers, Citi Sadar Road, Rawalpindi
    Advisors: Too many....
    Current Status: Read on and wish us luck....
    "If YOU don't believe in what you're doing it'll never work."
  2. #521
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456438
  3. #522
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    2JZ's Oil Pan is now clear of the Front Diff, which basically was the only reason to move the Engine back by 5.75 inches.
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456439
  4. #523
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456440
  5. #524
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Since the Oil Pan was shaved a bit in Rawalpindi to fit it over the Front Diff and it had oil seepage, so we decided to put in an un-tampered pan, to be purchased from Bilal Gung.
    Since the corner of the un-tampered pan would be only 1.25/1.5 inches from the Front Diff, it has been decided to raise the height of the engine by around 1.5 inches by putting in the new engine mounting plates
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456441
  6. #525
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456442
  7. #526
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Plate with 4 bolts, holding the engine will now be replaced with taller plates so that the engine rests 1.5 inches higher
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456444
  8. #527
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1456445
  9. #528
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Looking good! Ideally there should be a dry sump and engine lowered by a few inches rather than being raised. I don't get what is the concern with the tapered pan as oil capacity can be supplemented with an oil cooler.
  10. #529
    Jeep_junkie's Avatar
    Jan 2009
    201
    4 Post(s)
    Quote Originally Posted by saidhi View Post
    You don't really need to put any more than 1.5" between the oil pan and front diff as the diff does not move. It is mounted to the frame. The engine will not move more than 0.5-0.7" either even on the hardest jumps. There just isn't that much play in the engine mounts.
    That said, are you replacing the upper aluminum half of the oil pan too? If so, I'll take it off your hands since I need this configuration for my vehicle.
    Sent from my Nexus 5 using PW Forums mobile app
  11. #530
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Checked the cost of dry sumps over internet a few months ago,, they ranged from 3000 USD to 4500 USD,,, frankly a bit too much at this stage.
    The sump that came from Pindi was seeping oil, that is the only reason it is being changed
    We might taper the new sump and bring the engine back to where it was but we will finally decide on this once the shafts are fitted. Today gave the rear and front shafts for shortening/extending respectively, hopefully they will return by tomorrow evening.
    Since only the rear diff is at its factory settings, plan is to fit the rear shaft first and than align the mated engine/gear with it. If required, the engine will be lifted otherwise it will be kept at the previous position. In case the engine has to be lowered, I will get the new sump shaved from Lahore
  12. #531
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    @Jeep_junkie
    Sorry mate,,, need the aluminium piece but i am sure you will be able to find it in shops selling used parts, Suhaib Kiani bought it for me in Rawalpindi a few months ago
    Regarding the clearance, guess 1.5 inches should suffice,,, but its the idiot in me that I am more worried about
    This is from one of the early days, bad habits became worst later
    The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1457930
  13. #532
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Oh ho, Yasir se keh ke Thailand se sasta wala mangwa lein ge ham! Sheir Banein Saidhi Bhai, Sheir
    Engine (+gear) lowered by 2 inches is something serious..... and so is an engine raised by 1.5!!
  14. #533
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    @Jeep_junkie
    I believe, this was a mid or rear sump which is slightly rare but still should be findable.
    I would also think that 1.5 inch clearance on an IFS car should work no matter what, and if it doesn't then there has to be something else wrong somewhere.
  15. #534
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Nice to see the Rally season is ON...
    BTW Shairs are not doing well these days
  16. #535
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    Rear sump mod can be done with a 2JZ-GE sump and pickup. Just a few extra holes have to be drilled / tapped for oil return lines from the turbos. That way, the engine might be set down a bit for lower CG. Also, if you're so concerned about the engine moving that much, polyurethane or even aluminium alloy motor mounts are an option. It'll buzz like crazy, but it won't let the motor move at all.
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  17. #536
    tahamujtaba's Avatar
    Jun 2014
    Hyderabad
    19
    146
    7
    Any update ?
    Sent from my iPhone using PW Forums mobile app
  18. #537
    Proverbial_Slang's Avatar
    May 2005
    3,904
    29 Post(s)
    What sage is the build at?
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  19. #538
    yaserag's Avatar
    Jun 2005
    38
    748
    20 Post(s)
    So i thought that rather than starting a new thread lets just revive this one, So amongst other preparations that have been going on with regards to the project i recently came a across a scale model, build it yourself kit for the 2nd gen 4runer and i thought Why not!! So here is the result... the rally spec (read cut and b**terdized) Kaikra, should look something on these lines once its done... Khyaalaat are welcome..The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559401The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559402The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559403The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559405The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559406The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559407
    More Power!!! More power....
  20. #539
    yaserag's Avatar
    Jun 2005
    38
    748
    20 Post(s)
    Ive offset the rubber on the wheels to mimic the install of the long travel suspension. Also for some strange reason the rake is off with the model much lower upfront. With the actual vehicle the rake will be the opposite with the front being higher than the rear. I'm still debating whether the wheelbase should be extended. Lengthening the wheelbase does come at the expense of a longer turning circle. For starter we'll keep the wheelbase as is.... in the end this is what it should look like.The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559409The HiLex Kaikra and Pajero Evolution 2JZGTE Builds! -1559410
  21. #540
    May 2005
    3,904
    29 Post(s)
    Fantastic! The real test should be the jumps and the bumps.
