Page 29 of 29 FirstFirst ... 19272829
Results 561 to 570 of 570
Like Tree369Likes
Thread: The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Default The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    Toyota Hilux LN65 - 1UZ-FE V8 Transplant:
    Project HiLex Kaikra Build! -1221618
    Mitsubishi Pajero Evolution - 2JZ GTE Twin Turbo Transplant:
    Project HiLex Kaikra Build! -1221617
    Owner: Qasim Saidhi
    Builders: Awan Brothers, Citi Sadar Road, Rawalpindi
    Advisors: Too many....
    Current Status: Read on and wish us luck....
    "If YOU don't believe in what you're doing it'll never work."
  2. #561
    Jeep_junkie's Avatar
    Jan 2009
    201
    4 Post(s)
    Quote Originally Posted by sami_voodoo View Post
    It's mostly the elctronics that catch people out
    Hmm well, ecu wiring is very simple and similar for both early and late model non-vvti engines. The VVTi engines are admittedly more complex with DBW throttle and immobilizer equipped ecu, but I've seen so many successful swaps here in Karachi that it seems these items are no longer an issue.
  3. #562
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Proper as in
    1. New headgaskets
    2. New bearing shells
    3. New studs and bolts
    4. New pistons
    5. All new gaskets
    6. New oil pump
    7. New valves, guides, seats, springs and retainers
    ^^^ and that's just the parts.
    To your second point, be my guest, if you can find one. You know better than anyone that early UZs are getting rarer than hen's teeth. Of course a fresh junkyard UZ will cost less than a rebuild.
    Well the right answer to the trick question I believe would have been that you'd only go this route if your looking at FI. Otherwise, 1UZs are still available plenty enough and you could just go 1UZvvti or 3UZ. The vvti does not need a DBW and wiring is not an issue anymore for any of these.
    Nevertheless, on the "proppa" rebuild parts list, your kidding me right???!!! Your recommending this to me for an 8 cylinder engine, seriously!!??
  4. #563
    Jan 2009
    201
    4 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    @SuhaibKiani, all the 1UZ VVTi motors I have seen had servo actuated throttle bodies. Do you mean you can swap a regular TB on it and the ecu will correctly pick up the TPS reading? If so, that is fantastic.
    I too share your concerns on rebuilding these engines. 4 cams, 32 valves? Enough to cause nightmares!
  5. #564
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by Jeep_junkie View Post
    I believe some 1UZ vvtis do have cable actuated throttle bodies. At least all the two or three that were converted in Citi Sadar Road did not need the DBWs....
    To be clear, I am all for rebuilding engines wherever possible because its a skill and knowledge resource that you cannot do without in the long run. In that sense, Sami is right in laying down the list of parts that would be needed and I am just pulling his leg on the cost and benefit here. Nevertheless, the issue remains that even if one can get all the parts down, in a rally situation the engine remains at risk and there is precious little evidence of rebuilt engines lasting it out. I am not sure whether its the torque specs or some other missing link, but surely at this stage there is enough loose rope in there to hang yourself even if your very methodic about it.
  6. #565
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    I was infact going for an FI build. Otherwise, put in a later VVTi 1/3UZ and call it a day. There are *plenty* of those lying around.
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
  7. #566
    yaserag's Avatar
    Jun 2005
    38
    748
    20 Post(s)
    Dobara hisab karein! Hi-Lex Kaikra + IFS Conversion + 5VZ install = winner
    1UZ aur clutch chit meray khaatey mein!
    kar liya hisaab, A category sae door rehna hai... plus too far down the 5vz route anyway...trd supercharger aa chukka hai.. aur IFS long travel bhi pakar liya hai..
  8. #567
    yaserag's Avatar
    Jun 2005
    38
    748
    20 Post(s)
    Btw i hear farooq has a new wshop... where is it? I'm here till next friday...wanted to check it out
  9. #568
    saidhi's Avatar
    Mar 2008
    46
    1,630
    24 Post(s)
    Quote Originally Posted by yaserag View Post
    Lahore ka kya plan hae?
  10. #569
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Workshop is close to the old one, but on the Main Railway Road linking CSR to Westridge / Rata.
    We normally use this road for testing and its just right of the second speed bump.
    Let me know when your free and we can hop along there....
  11. #570
    yaserag's Avatar
    Jun 2005
    38
    748
    20 Post(s)
    Quote Originally Posted by saidhi View Post
    sorry boss, in peshawar for a family wedding. Will follow it up with a few days in pindi with parents.
    SK, we'll have to do it on a weekday. I leave friday. What time do u normally get back from work?
