Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree6Likes
Thread: HELP: Overheating problem with A/C
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Question HELP: Overheating problem with A/C
    pajero gen 1 turbo diesel 4d56.
    the problem is that when i turn on the a/c, after 20-30 min the temp needle guage goes at 50% in the middle & that makes me start to worry, and afterwards when the car stops after long drive, most of the water from radiator is evaporated & i have to refill it & top it up, the radiator coolant reservoir bottle is working fine, and everything ok with no-leaks in radiator & condensor fan also working.
    This problem only occurs when turning A/C on.
    But also, there is no coolant in the radiator, im only using water.
    is it necessary to put in coolant? if yes , then which company coolant & how much?
    Or do i have A/C Compressor problem ?
    help is needed asap.
    Thnx for ur time.
    Vehicle History: Pajero 1 & 2 (4d55 Non-Turbo - 4d56 Turbo & 4M40 I-C Turbo) / Land Cruiser BJ60(13B-T Turbo) / Nissan Patrol GQ(Td422 Non-Turbo)
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    Dear this engine has the ability to get overheat,and turbo makes it more if inter cooler is not fitted....there might b some issue with the compressor also but the main issue with this engine is this that it overheats and which leads to the engine seize.
    it is recommended that u should use at least 2 bottles or 2 liter coolant in the radiator...moreover u should install a cut out relay on the ac fan.
    moreover while driving keep its RPM below 3000.
    if the engine is overhauled and is installed with after market sleeves,that can also b 1 of the reason.for further details feel free to call me at 321-4392122
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Quote Originally Posted by lateralus View Post
    Thnx-A-LOT for the support brother! I've got ur number, Thnx for that, i will keep disturbing you in & out
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Check your Fan.. is the clutch fan fixed? or still has the viscous coupling?
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Can installing 2 condensor fans help to reduce engine heat-up & cooling?
    Should i install another condensor fan ?
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    it would make a lil difference...but if the engine is not properly overhauled ur issue will not b resolved ...i mean there r multiple reasons but 1 reason can be improper head facing ...1 can b timing adjustment...other can b after market sleeves...multiple other issues...
    Quote Originally Posted by fuma View Post
    From 2.0 Toyota Corolla to 2.5 MMC Pajero ...Corolla u ll always b missed...but the life goes ON...
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    also check whether when u press the ac button the fan starts outside or not....install a cut out relay to the fan...u might get some favorable results
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Condenser fan is working all good, it starts at the A/C push button, it is doing its job perfectly.
    & engine is all in genuine condition, no alteration/modification or aftermarket fixes.
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Check engine radiator fan.. is it mechanical viscous coupled? It looses its viscous coupling properties over time.. fails to pull enough air through radiator to cool off when not moving
    Sent from my GT-I9500 using PW Forums mobile app
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Quote Originally Posted by akifjanjua View Post
    Fan is locked with permanent fully engaged setting,
    thus drawing high volume of air continuously.
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Is the thermostat installed?
  12. #12
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    thermostat is all OK
    besides, as im from Karachi, the temperature here does'nt needs thermostat,
    as it is strictly only needed at 0 Degree Celsius or less to warm up the engine asap.
  13. #13
    kashmann's Avatar
    Apr 2009
    43
    120
    either engine is creating gas or your pulley belts are getting too much friction resulting in compressor heating up thus heating up engine too
  14. #14
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Thermostat is absolutely required no matter wherevu live.. it regulates the coolant flow
  15. #15
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    dear after playing alot with pajero engine ...i will only say that over heating and pajero engine go all together under stress.
    so only one solution......
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
  16. #16
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    3 c turbo
    Quote Originally Posted by joinami View Post
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    the cooling fan being locked can be very bad - it can sap upto 10 hp from the engine, the clutch itself is a very neat device, it couples up when hot and decouples when rpms or fan load becomes high.
    In your case it seems like some air is trapped in the engine/radiator and the coolant flow is hampered.
  18. #18
    fuma's Avatar
    Dec 2007
    32
    231
    4 Post(s)
    Guyz,
    Let me underline the scenario again:
    Vehicle only gets HOT in IDLE position
    for 15-20 min & looses cooling effect gradually.
    As the vehicle is back on the road, then everything is OK.
  19. #19
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    So here the problem is. Just change the fan pully with a smaller one and it'll increase it's circulation even in slow rpm. I hope it works.
  20. #20
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    I have found the engine oil cooler to be a good addition to turbo diesel engines to help keep them run slightly cooler. Understand that some Gen 1s / GenIIs have oil coolers installed from factory. Nevertheless, there seems to be a basic problem with the cooling system here....
    "If YOU don't believe in what you're doing it'll never work."
Tags for this Thread
