Results 1 to 12 of 12
Thread: 3S-FE Hilux Double Cabin and 1.0L A/T Daihatsu Duet..
    marrijali's Avatar
    Feb 2012
    227
    Default 3S-FE Hilux Double Cabin and 1.0L A/T Daihatsu Duet..
    Hey Fellow PWs...
    got another prob, dad 3s-fe hilux is missing on petrol, when you start the truck and let it idle it misses, and as soon as it comes on cng no missing. the engine has been swapped.. the ECU has written on it that is 3S-FE (AT).... dont knw what the previous owner did.... but got it in this condition.... so what to do ??
    2---- my uncles Duet is just Pitta ,its a 3 cylinder engine EFi, the car wont start on cng or petrol... i just flashed the ecu cleaned the throttle body with throttle body cleaner spray....
    but when we just try try and try it starts and idles like a mazda T3500.... its like the engine is blown...
    found the Diagnose port. but has nathing written on it like TE1 or E1...
    PWss What to do ???
    Never Play For The Team, Always Play For Your Own FAith !!
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Get the injectors of hilux cleaned and compression pressure of duet need to be checked for proper diagnosis.
    Never loose hope in life,every step gives u something.
    marrijali's Avatar
    Feb 2012
    227
    the hilux engine has recently overhauled... Changed the injectors with dual feul pump......
    The duet show good compression. But still it exist..... Year back the throttle body of the duet was changed... And it got good... Now what i do? Change again the throttle body...???
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    check petrol as we are getting rotten petrol here in karachi which dont even burn properly and dont even evaporate like before and have bad smell
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    probably of the topic... but can you tell me what price range your father got the hilux for?
    the problem is not our govt... its the people..
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    for the duet if everything is ok... seems to be a sensor malfunction...
    first remove all cng related wiring... and try to run it only on petrol... check fuel pump flow and pressure.. check ignition... plugs one by one and their respective spark..
    does it have obd2 port?
    marrijali's Avatar
    Feb 2012
    227
    got the hilux without engine... The gearbox was there and required dent paint... We bought it for 5lac... And the engine was lying at home....it all came up with the cost of 7lac with total new stuff...
    Rocket_mullah's Avatar
    Jun 2011
    Peshawar
    1,528
    22 Post(s)
    50lac for a hilux with no engine wow can i get the stuff your smoking
    Bodybuilding supplements + steroids for sale PM me 0345 9595950
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    5mil? 5,000,000 are you serious??? or do you mean 5 lack?
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    which model was it?
    marrijali's Avatar
    Feb 2012
    227
    itx 5lac, itx just iphone auto correct sucks :p.... but the price is not the issue the main prob is the missing and the radiant junk Duet......
  12. #12
    marrijali's Avatar
    Feb 2012
    227
    Quote Originally Posted by nfssaad View Post
    Quote Originally Posted by Rocket_mullah View Post
    i corrected it on a pc, tried to edit it on phone but still change it back to "m" .... sorry fellows.. if had this much why invest on this get a new imported land cruiser :p
