Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 150
Like Tree202Likes
Thread: Frontier 4x4 Club New Entry (BARBAROSSA)
    BKyousafzai's Avatar
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    Default Frontier 4x4 Club New Entry (BARBAROSSA)
    Frontier 4x4 club new rig
    Name Barbarossa
    Engine 1KD-D4D-
    Rig: BJ60
    tyres. 22 in LP + perali Scorpion mud 16 in
    time of Completion 53 days
    Jasma Down piping
    king rally suspension on way
    Weight 1865 kg
    Roll bars locally fabricated
    Bucket Seats with six points belts.
    Chipped by UNICHIP Pakistan
    BKyousafzai
    Frontier 4x4 CLub
    Frontier Rally Team
    powered by BK
  2. #101
    owais8668's Avatar
    Mar 2012
    Nowshera
    24
    2,316
    27 Post(s)
    well done BK bhai....congrats for the new machine, hats of for ur efforts...
    Which of my photographs is my favorite? The one I?m going to take tomorrow ....
  3. #102
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    Quote Originally Posted by jehanzebnasir View Post
    BK deer allaa, da kho islamia college akhkare?
    awoo gee tasoo tek wayee
    powered by BK
  4. #103
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    Quote Originally Posted by owais8668 View Post
    Thanks owais
    powered by BK
  5. #104
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    BK!! Have you checked the CG of this rig bcoz after reducing the weight from behind shifts the CG behind and God forbid in a rally if the rig lifted, it will touch the ground nose down and may damage the front. For that you may need some more weight to be installed behind to bring the CG forward.
    Khalid Khan
  6. #105
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    Even climbing down on a steep terrain will immediately pull the tail up if a brake is applied.
    Khalid Khan
  7. #106
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    And keep your CG as low as possible bcz as you burn your fuel it will further move the CG behind and will make your rig nose heavy....You can calculate your rig CG easily with the help of a Physics teacher or student.It will definitely give you more control of your car in high speed which you are gonna do
    Khalid Khan
  8. #107
    ajab9007's Avatar
    Nov 2008
    Swatmingora
    25
    2,950
    16 Post(s)
    Quote Originally Posted by TheAviator View Post
    that's what i told him to add some weight to the rear.
    Never go offroading alone!!!you never know when you need a push!!
  9. #108
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    From what I have seen, having a light rear is not all that undesirable in our rallies where we have cars running in 4x4 and very few "air" jumps on the tracks. Nevertheless some sort of optimal balance has to be achieved and the car will under steer a lot more (for which you have to work out your particular steering control technique) and for Cholistan "khabbars" you have to learn how to drive the "wheel-barrow" on front wheels with rear bouncing up and down...........
    However once suspension is all in, the rear kamani will have to be adjusted here by reducing number of leafs which are calibrated for stock weight. Possibly also look into moving the shackle hanger forward a bit to get a better shackle angle because from the pics its looking like a very stiff ride at the back...
    I would be more concerned about the rear diff being off the ground a heck of a lot and losing traction on bumpy terrain and would recommend either replacing rear ghucha with 80 series LSD or a full 80 series rear tube with a locker....
    "If YOU don't believe in what you're doing it'll never work."
  10. #109
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    get 2 x steel boxes fabricated 24 x 24 x 18 inches with base plates and use U-bolts to Tie down when venturing to a rally add / reduce weight ( sand in bags) as & when required will solve the tail lifting tail swings.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  11. #110
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Quote Originally Posted by SuhaibKiani View Post
    Do you guyz achieve speeds in a rally where the Rear Wing comes into the equation. As you mentioned that there are hardly any air jumps, so if you put a rear wing does it make you life a lil better on the steering wheel.
  12. #111
    lateralus's Avatar
    May 2009
    30
    555
    24 Post(s)
    Frontier 4x4 Club New Entry BARBAROSSA -1244468Frontier 4x4 Club New Entry BARBAROSSA -1244469Frontier 4x4 Club New Entry BARBAROSSA -1244470
    here are some pics for your kind consideration please ...they are somehow the same as Barbarossa and they have roll bars outside the body
    One major reason to install safety roll bar inside is bcoz it produces drag .........chk rally cars on YouTube..
    From 2.0 Toyota Corolla to 2.5 MMC Pajero ...Corolla u ll always b missed...but the life goes ON...
  13. #112
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    Quote Originally Posted by lateralus View Post
    Thanks bro for your professional advises and input.
    regards
    BK
    powered by BK
  14. #113
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Quote Originally Posted by hsumbal1 View Post
    Aerodynamics can help get you from 19 to 20 on certain things in offroad racing, but they cannot solve fundamental issues like weight balance as such......
  15. #114
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    None of them are rally cars but off roader's and only used for terrain climbing or into mud......I am talking purely about rally cars for which you need aerofoil shape outer fairings to minimize the drag so outer safety cage is out of question....
    Khalid Khan
  16. #115
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    and less drag means more speed and less fuel consumption
    Khalid Khan
  17. #116
    TheAviator's Avatar
    Jun 2013
    47
    603
    13 Post(s)
    That's why I said shifting of wt & balance shifts CG........getting air lifted even for an inch increases stress on the front suspension and if CG is moved to aft, it will be like an uncontrolled Wheel Barrow as you said above.......and the steering control technique if none will make it more worst.......Suhaib!! you had experienced the Cholistan track and can share your experience of high lifts/jumps on bumps....
    Khalid Khan
  18. #117
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Yaar best thing would be to take videos of the car at high speed jumps and rough tracks and analyse them. It is a fact that driver ko at times pura andaza nahin hota ke assal kahani kyaa chal rahee hai, videos and photos tell a better story! Its a lot of work fine tuning the suspension of a offroad race car. Some of the professional baja teams spend weeks tuning shocks before every race. Our life is somewhat simpler because we have all the less things to play with here:
    1. Tyre at the back (one / two / large / small / heavy / light) - makes a difference, along with how far back....
    2. Kamani number and tarr angle: lots of rope to hang yourself with but as few as you can go while maintaining proper angle and not breaking springs (yes they do break!)....
    3. Shackle length: longer ones at the back can be tried for some more travel as long as back not raised too much...
    4. Shocks: Always worth the investment. BTW which KING shocks have been ordered here?
    Cholistan kee mat yaad dilaein, kamar mein dard shuru ho jaata hai
  19. #118
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Very true Suhaib Kiyani
  20. #119
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    Buket Seats
    powered by BK
  21. #120
    Oct 2011
    Peshawar
    2,127
    6 Post(s)
    4 Thread(s)
    3 inches Down piping
    powered by BK
