Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Like Tree17Likes
Thread: TLC 80 Series Swap 1UZ-FE
    Bhutto's Avatar
    Mar 2008
    835
    Default TLC 80 Series Swap 1UZ-FE
    Assalamalikum everyone , I just bought a land cruiser 80 series (4.2 Diesel) but i think its underpowerd and i was thinking to convert it to Petrol . Now as i have researched , am interested in 1UZ-FE ( vvti or not ) to swap in my cruiser . My Questions are :
    1. What about the transmission? Will it work with my current one ?
    2. 1UZ-FE is a Rear Wheel drive engine and the cruiser is all time 4wd ( as far as i know ) so will it work with the 4x4?
    3. Is it an easy just bolt on swap or there would be some cutting or anything like that ?
    4. The prices here are quite high as compared to Ebay. VVTi is for 250k to 270k here . Will importing the engine be better ?
    Thanks.
    Regards .
    Do or Die , Kill or be Killed ...
    Bhutto's Avatar
    Mar 2008
    835
    And one more thing , I was planning to change the shocks and coil springs and install the ones in Land Cruiser Cygnus 2006 . Will they give out the same performance as Cygnus ? And what about cost ?
    qwertypoiu's Avatar
    Feb 2007
    29,141
    153 Post(s)
    3 Thread(s)
    Well they say 1uz is not suitable for 80 series. 2uz with its auto gear is way to go it will require cuttin etc. other option will be 1fz-fe it will fit bolt on.
    for suspension get iron man nitro shocks or old man emu nitro shocks
    RIP
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    These days it should not be a problem, a lot a 1UZs are finding their way in the TLC40s and other vehicles.
    1. Yes your transmission will work fine with a 1UZ
    2. The 4X4 in not dependent on engine. It needs a transmission which you have full time 4X4 should not be an issue at all.
    3. I think some cutting pushing and shoving will be required for the swap. And you will need to fabricated an adapter plate to couple the gear to the engine.
    4. No idea bout the price but I think it is not as expensive as you think. You need to do some first hand research.
    Bhutto's Avatar
    Mar 2008
    835
    Thanks for the quick replies .
    Actually i was thinking of more horsepower and from that i thought of the 1UZ-FE. 2UZ is 236 hp and 1UZ is 256 ( the non vvti version )
    @qwertypoiu
    Sir how much these iron man costs and i dont want a lift up , i just want the comfort like cygnus
    Bhutto's Avatar
    Mar 2008
    835
    @hsumbal1
    Sir the adapter plate is called hosing or housing ( something like that ) by the mechanics ? is that the same one?
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Quote Originally Posted by Bhutto View Post
    @hsumbal1
    I actually haven't taken such a swap, but Bell Housing is somthing different to Adapter Plate.
    I think there are two ways of doing it(gurus please correct me if I am wrong) on is to some how find the way of attaching the bell housing of the 1UZ to the 80 series box which might be a bot tricky the other one is making an adapter plate.
    But I have seen quite a few engine and gear marriages thru adapter plate.
    You can go thru this thread it might answer some of your questions.
    The Hi-Lex 'Kaikra' and Pajero Evolution 2JZGTE Builds!
    hasan.nqv's Avatar
    Jul 2010
    Rawalpindi
    296
    2 Post(s)
    adapter plate is a custom made plate btw gear box and bell-Housing.. it is used everytime in engine swap when not done with stock gear of the engine..
    qwertypoiu's Avatar
    Feb 2007
    29,141
    153 Post(s)
    3 Thread(s)
    @qwertypoiu
    then buy cygnus :p, iron man nitro shocks 1.5 lack i believe
    RIP
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Its possible, though would ruin the market value of the car...
    "If YOU don't believe in what you're doing it'll never work."
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    The 2UZ should be more suited here than the 1UZ, although the 1UZ vvti should be almost close to the 2UZ. Torque is more relevant than BHP here as 80 is a heavy car...
  12. #12
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Auto and Manual gear should both be possible, though not without modifications....
  13. #13
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    1UZ vvti should be around 120k....
  14. #14
    Bhutto's Avatar
    Mar 2008
    835
    @SuhaibKiani
    Market value doesnt matter , specially of these old models . My question is
    1UZ vvti is 300 torque and 2UZ is around 311 , but on the bhp vvti is 300 although 2UZ is around 236 , dont u think 300 torque can handle LC ? because on the other hand the vvti has 300 hp , thats quite alot
    Secondly , where can i get 1UZ vvti in that range of 120's ? And how about mating a 5 speed automatic transmission ( taken from 2UZ ) to the 1UZ ? How much that transmission will cost ?
  15. #15
    TLCFJ40's Avatar
    Sep 2006
    37
    1,784
    7 Post(s)
    Have a 80 with 1 fzfe and will only recommend u the same. No modification needed. Petrol gears and diesel gear have different ratios u are better off putting in a engine tranny for a better ride.
    Lc 80 k genuine electric ahock dalwah lou which are for 45 grand. Sports and normal setting will give u both soft and hard ride.
  16. #16
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Hmmm, actually Salman is right that the simplest of conversions should be the 1FZ, but obviously the financial proposition for a 1FZ engine and gear is something to think about.
    1UZ vvti (with its auto gear) is available from Haji Zaman in Rawalpindi for around 125k. The auto can be mated on some Prado and Surf gears without any coupling but in all likelihood would need a custom made coupler (which is somewhat more complex than an adapter plate) between the auto gear and the transfer case. I am not sure how lastable this jugaar is, but there is a conversion ongoing on a Land Rover and I will post some pics in a few days....
    The 1UZ vvti vs 2UZ is a long discussion, but you are right in terms of there is a trade-off ad the 1UZ is interesting particularly if you are not doing heavy offroading with the rig...
    Best of Luck!
  17. #17
    Bhutto's Avatar
    Mar 2008
    835
    Any superchargers or turbo kits for 1FZ here ? Because i need more bhp .
  18. #18
    qwertypoiu's Avatar
    Feb 2007
    29,141
    153 Post(s)
    3 Thread(s)
    Didnt your previous prado seem under powered ?
    RIP
  19. #19
    Bhutto's Avatar
    Mar 2008
    835
    it was underpowerd , still i tried to upgrade the performance but it would be easier in a Petrol engine.
  20. #20
    TLCFJ40's Avatar
    Sep 2006
    37
    1,784
    7 Post(s)
    yea turbo and super chargers are available for fz engines..by the way what do u mean by underpowered? if fz- fe or 1 hdfte is underpowered in a lc 80 than who told u a 1uz will work for u, as to my knowledge after u install 1uz in a lc 80 u will call 1fz over powered. If u want more punch out of ur lc 80 go for 2uz or 1fz fe with a charger/ turbo kit. Which engine is installed in ur cruiser anyway. 1hz/1hd-t or 1hd-ft.?
    Toyota All The Way !!!!!!!!!
