Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By SuhaibKiani
Thread: Toyota 3L gear question
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Default Toyota 3L gear question
    Last month i purchased a russian UAZ which has a non efi 3L engine in it with a 5 speed gear. As per the last owner, who owns a big workshop in isb, told me that they used to work for UNOPS and had fixed this engine and gear from one of the UNOPS veh which had rolled over and they purchased it. The veh was toyota tiger, double cabin, between 2003 to 2006 model. Now i have the following questions
    1. Is the existing 5 speed gear is the one which we normally call, "choti kit wala" or "bari kit wala"?
    2. And what's the difference in both of them?
    3. Any torgue or accelleration difference
    4. And are they of the same size and can they be attached with a 2L?
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Bump, i think someone should know about this, not a very difficult question.
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Its kind of difficult to tell unless you look at the gear physically and even then at least I cant tell them apart. But if its actually off of a 3L, I would assume its the bari kit wala....
    Ummm, again despite some research here I am not 100% certain on this but my understanding is that the choti kit is the R150 (with longer gear rations) and the bari kit is the R151 (with shorter gear ratios). I might be completely wrong here, and they might be the other way around and not related at all, but that is what my best understanding is....
    For sure, the bari kit is heavier in construction and with shorter/lower ratios resulting in heavier fuel consumption and slower acceleration in most cases...
    4. And are they of the same size and can they be attached with a 2L?[/QUOTE]
    Yes that is my understanding, no fitting differences between and 2L and 3L plus no real external size differences between two gears. My CJ runs a 2LT with bari kit gear....
    "If YOU don't believe in what you're doing it'll never work."
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Thank you suhaib bhai. I knew you'll reply. Got some lead at least. Will further do my work from this onwards.
    Thanks
