Results 1 to 5 of 5
Thread: Having Trouble In Nissan Safari Gear
    welowcity's Avatar
    Aug 2008
    36
    37
    Default Having Trouble In Nissan Safari Gear
    Hi
    I recently buy a Nissan safari which is converted from manual to an auto transmission not by me and it having a shifting problem some mechanic told me that "the sensor which is located over main throttle body which controls the shifting may be out of order so you should go to some good mechanic who can connect it to a scanner".
    So can any one guide me where can i find a good mechanic who can fix my problem.
    And i know that auto transmissions are disposable but if it is only a sensor problem then i think there is a hope.
    I like to convert it to manual again so any idea of price and from where i can find gear box except shear-shah market
    Thanks
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    the problem was thr when u bought it?
    what exactly is the problem
    welowcity's Avatar
    Aug 2008
    36
    37
    yes it was present from very first day
    gear shifts with very huge jerk and it shifts only three gears and it dosent shift down when i pump the throttel
    the power button also known as overdrive button do nothing
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    please state model year of Safari, engine it is having under the hood & transmission coupled to it. I strongly feel that ECU is not swapped / or properly wired as u stated about power button not functional. Please check your PM for details to Diagnostic dude.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    welowcity's Avatar
    Aug 2008
    36
    37
    Thanks A Lot Capsat For Your Help I Viewed Your PM And I will update with the result of visiting him
    model is 1991 under the hood it have 4.2 non turbo diesel engine not know the transmission model and i will be more thanks full if u guide me about the price and suppler for manual gear
Tags for this Thread
