Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By hsumbal1
  • 1 Post By noman8ff
Thread: Bj 40
    khalil18's Avatar
    Jan 2013
    Peshawar
    Default Bj 40
    Dear, I need suggestion for my bj 40 1980 it has b old engine it's very noisy, it's weak, should I overhaul the engine or replace it to b3. Wise advice need. Thanks
    adnan_asim's Avatar
    Oct 2005
    33
    562
    I think u should change it from better one
    M aDNAN aSIM
    I want to Spend my Life On Roads
    adnan_asim's Avatar
    Oct 2005
    33
    562
    Peshawer Shohba Bazar
    Rawalpindi Sultan dee Kooh
    Lahore Bilal Gunj
    Karachi Sher shah
    M aDNAN aSIM
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Quote Originally Posted by khalil18 View Post
    If your vehicle has an original B stick to it. 3B will not make your life better in terms of Power and noise both. We have a lot of FJ40s around us but the original BJs are getting rearrer so keep in mind that.
    Just get the engine overhauled by a good mechanic get evry mecanical thing in order and forget it for 10 years.
    If you still want to change the engine then there are other options.....B to 3B doesn't make sense.
    P.S. If possible Kindly post the pics of your ride in detail.
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Agreed with the upper reply, just get it overhauled, if it has an original B2 engine. It's very powerful, better fuel efficiency than the 3B and most importantly is original. These 40s are slow moving tough machines and most of the new engines are designed for high speed which is useless to be put in a 40. 2B is non efi, non turbo and is hence totally trouble free engine.
