Results 1 to 19 of 19
Like Tree18Likes
  • 1 Post By baigaqeel
  • 2 Post By spectra
  • 2 Post By VCheng
  • 1 Post By Saaduk
  • 3 Post By VCheng
  • 1 Post By hameeds01
  • 2 Post By qwertypoiu
  • 2 Post By baigaqeel
  • 1 Post By PKTUN
Thread: 1kzte ecu
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Default 1kzte ecu
    My ride ECU is dead.
    It is 1KZTE M/T (Manual Transmission)
    Nameplate data is
    89661-60230
    175800-1283 12V
    Make DENSO.
    Could not find it & have replaced with a 1KZTE A/T
    Nameplate data is
    89661-26170
    175800-1335 12V
    Make DENSO
    Now the ride is OK with following issues
    Engine IDLE RPM are little higher i.e. around 900-950 RPM which I presume are due to A/T ECU
    Engine Manual Choke Button is not working.
    I have not given a long run to my RIG,
    My question is
    What issues I can encounter if any.
    Or This ECU will serve the purpose
    Have a nice day
    Aqeel Baig
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Manual choke button has nothing to do with ECU and Idle rpms can be higher because of some input missing to the ecu from transmission.
    Keep a cool head and wear seatbelts!
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by spectra View Post
    @spectra
    Manual choke button signals ecu to increase rpm and it sends signal to fuel pump which increases fuel & hence rpm.
    Regarding increase idle speed. No input is missing as same behaviour on another manual ecu which I borrowed. Also another automatic ecu also increases idle speed.
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    It is better to get the correct ECU for manual transmissions, if you can find it.
    ECUs for automatic transmissions do all sorts of adjustments when they get a signal that the transmission is going to shift, in order to provide a smooth shift. Those maps will not work properly with a manual transmission.
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by VCheng View Post
    Looking for manual ecu. Till then no other option.
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by baigaqeel View Post
    Agreed. The auto ECU will work if there is no other choice, but sooner or later you will find the correct ECU. Good Luck!
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Any other technical comment on usability of A/T ecu in place of M/T ecu
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Is your throttle position sensor properly adjusted? EFI replaced the normal choke to IDLE UP switch. As far as I remember, I tried both ecus on my manual 1kz but never had any issues.
    Drive a Legend. Drive a Land Cruiser
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by Saaduk View Post
    Manual ECUs use a different shift logic, with a delay in throttle liftoff to cause a delayed and more gentle transitional overrun to save fuel and reduce emissions. Automatic ECUs reduce fuel and retard timing to secure a smooth shift and prolong clutchpack life.
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Whts wrong with ur oem ECU??? Most of the ECUs r repairable but no one take the risk due to limited knowledge
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Dear @Saaduk
    the throttle position sensor is properly adjusted.
    I gave 200km + Run on this A/T ECU last week. It is working fine but found out some minor issues
    At start Engine Idle RPM around 950 RPM & after a few seconds come to 900 RPM.
    When I shift to 1st or Rev gear, RPM drop to 650 RPM which are correct with Manual ECU.
    Aqeel
  12. #12
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    @VCheng
    Any after effects on Engine Timing on prolong use of A/T issue.
    See my reply to @Saaduk also
    Aqeel
  13. #13
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by hameeds01 View Post
    @hameeds01
    had it repaired but lasted one week only.
    Now the repair guy says it is beyond repair.
    Also you are stuck in middle of nowhere, if it is dead.
    So now I have another A/T ECU as spare in my ride
    Aqeel
  14. #14
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    @VCheng
    Aqeel
    Nothing major I suspect, just suboptimal performance. Besides, an A/T ECU is better than NO ECU at all.
  15. #15
    qwertypoiu's Avatar
    Feb 2007
    29,132
    153 Post(s)
    3 Thread(s)
    Aqeel bhai swap in Auto gear and enjoy sakoon bhari driving feel if auto vehicle. Your existing gear will be given and 10k on top you can get auto gear. Ask @Libra how his life changed when becharo was converted to auto
    RIP
  16. #16
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Aqeel bro you must try and i hope you will soon find the manual ECU i believe. as no match to manual transmission in 4X4 applications.
    also try to ask some one in japan to fetch it for you .
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
  17. #17
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by joinami View Post
    @joinami Bhai, I am trying to find & get one from Dubai. Agreed, there is no match of Manual Transmission in Off-roading.
  18. #18
    baigaqeel's Avatar
    Apr 2008
    51
    2,693
    68 Post(s)
    9 Thread(s)
    Quote Originally Posted by qwertypoiu View Post
    @qwertypoiu
    I waited 2 years or so for a M/T ride.
    You feel the control in you hands.
    & the most is in Off-road. specially in uphill & downhill tracks.
  19. #19
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    4x4 auto ? what a joke i fully agree with AB 4x4 ride ka maza shashka hee manual transmission mai hai imagine k you have a mule to travel off road but with no lagaam heheh !
    AB good luck
    freedom of speech (less country family & religion)
