Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By capsat
Thread: Toyota Land Cruiser 2006
    ozzeyy's Avatar
    May 2010
    27
    78
    Default Toyota Land Cruiser 2006
    Toyota Land Cruiser 2006 -1283387Toyota Land Cruiser 2006 -1283388 having LC.its GX.R v6 Automatic Scheme from Japan. Its only driven in QATAR.
    having ABS Brakes system. the brake loosen sometimes while driving and becomes normal after few moments.
    the Problem increasing day by day . mechanic suggested to replace the whole ABS brake system.
    is it repairable or not?
    Expert opinion required
    Regards
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Post
    Before you get ripped off for ' system swap ' - please check & replace brake booster PCV valve. a pipe connected on booster running from intake manifold in between is a plastic valve called Booster PCV valve. Do share result after replacement.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    please update
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by ozzeyy View Post
    Regards
    You probably need a new Master Cylinder and ABS Pump assembly. It lists for about $1800, but can be found cheaper. A salvaged part may also be a good option, but you should get it scanned first for error codes.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Only Brake Master Cylinder Need To Be Overhauled Or Replaced.
    Never loose hope in life,every step gives u something.
