Results 1 to 15 of 15
Like Tree5Likes
  • 1 Post By akifjanjua
  • 3 Post By noman8ff
Thread: BJ 60 swapped with 2jz transmission problem
    gallian007's Avatar
    Feb 2008
    25
    59
    Default BJ 60 swapped with 2jz transmission problem
    Guys please need some advice for my BJ 60 1983 Landcruiser in which I have put a 2 jz and didn't change the gear (5 speed forward original). Engine is fine but I am not satisfied with the engine gear compatibility and the power which I was expecting from 2jz egine. First there is issue with the adaption plate (Hosing) which on repeated repair still gives problem. Secondly should I go for any other gear and do I need to do anything about differentials (Hissa)??? so that the power is not compromised and I also get some more speed. Somehow Jeep is lagging and not that responsive. Desperately need your suggestions and advises/
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    will happen if you use a car engine in a landcruiser.. its a tradeoff..
    Sent from my GT-I9500 using PW Forums mobile app
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    gallian007's Avatar
    Feb 2008
    25
    59
    That is very true but its better then my really messed B3 engine. this engine was in my range and due to my lack of knowledge, it so happened. I would have loved to put a 12HT but budget was the issue
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    You are probably looking for your Toyota Land Cruiser to behave like a Toyota Supra.
    That wont happen. A 3B, Whether it was messed up or not was lot better than a 2JZ.
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    a bad decision regarding the size of that jeep !
    i guess ull be already having diff of diesel as well ! so cant improve power any further via that !
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    a 1uz was a better choice in same budget.. and a 3B could be rebuilt to as new
    anyways.. I dont want to advise you to spend more on re gearing diffs with this engine.. keep using it as is.. or go for a good 1uz swap
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    Hi bj 60 it's to heavy over 2 ton. The only is
    New gearbox
    Transfer box
    Rear diff
    All of the above have to be changed for bigger bhp items.
    Pakistan.. Toyota hilux..golf mk2 gtd..rolla 2.0d..nissian sunny.. Yamaha pw 50.. Coventry uk....audi v8 d11..golf mk2 rallye..honda crx..evo 8..golf mk2 gtd..Vauxhall insignia..
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    remove the manual transmission and mount the toyota prado 1996 4wd automatic transmission with the 2 jz and then you will see the performance out of your cruiser. no diff changes are required for that if you change the transmission for more info call at 0311-5135516
    rehman auto's
    noman8ff's Avatar
    Oct 2007
    41
    1,757
    10
    72 Post(s)
    This is bad. But done is done, just forget the past. My assessments are as
    1. No need to think about the diff or tube changing. That will be another fuss adding to the existing problem.
    2. 2JZ will always a be a problem for a 2.5 ton heavy vehicle with any gear.
    3. You are in a so called trouble situation, just take a bold step, sell the 2JZ and overhaul the existing 3B which is a monster engine in low gears and the best as far as economy is concerned.
    4. A 3B can be overhauled to 100% as it gets sleeves and keeps it on zero sized pistons.
    5. 12HT is powerful but again not recommended unless you own a petrol pump. It doesn't give any better average than 5.5 or max 6 ltrs in a ltr.
    6. And lastly, if you need power only in low gears and do not bother about the top speed, you can even go for a 2B as well. In the early models of 60's, toyota has put 2B's as original engines. It will be less expensive to purchase also.
    Regards
    sami_voodoo's Avatar
    Sep 2004
    35
    3,701
    8 Post(s)
    It may be that your engine (2JZ) isn't in that good a condition. Is it the later VVTi or an earlier version? In a 1.5 ton Pajero, the 2JZ needs to be wound up a little bit to give good progress, but when it goes, it goes HARD. Even in a 2.5-ton vehicle (which it isn't, it's closer to 2 tons), the 2JZ shouldn't be sluggish by any stretch of the imagination. You can look up the power and torque specs on both engines to get an idea of what to expect.
    Wise men think alike and fools never disagree...
    A siren is just a woman's face on the body of a Tuna...
    gallian007's Avatar
    Feb 2008
    25
    59
    I know it wasn't a good choice but whats done is done. @Noman I dont have the old 3B, i old it when I was changing the engine.
    What will be the cost of a 1uz swap? and what about landcruiser 2's gear price as atta said???
    sami...Its the old one i am afraid but engine is perfect I think. ALl the problem is with gear and as everybody is saying, poor choice of engine for a cruiser
  12. #12
    Proverbial_Slang's Avatar
    May 2005
    3,903
    29 Post(s)
    What is the current status?
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  13. #13
    gallian007's Avatar
    Feb 2008
    25
    59
    Its going ok. Never let me down be it to naran, babusar, deosai, skardu, bhanjoosa lake, toli pir and u name it. Still not as smooth as one would like it to be but chalta hai. Though I ended up buying another with a 12HT, high roof :-)
  14. #14
    May 2005
    3,903
    29 Post(s)
    Quote Originally Posted by gallian007 View Post
    Mubarak
    Pictures please.
    Sent using Curiosity's onboard communications sytem.
  15. #15
    gallian007's Avatar
    Feb 2008
    25
    59
    BJ 60 swapped with 2jz transmission problem -1557364
