Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Like Tree28Likes
Thread: Help @Xulfiqar: Toyota Land Cruiser Error Codes
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    Exclamation Help @Xulfiqar: Toyota Land Cruiser Error Codes
    a friend of my father imported Land Cruiser 2011-12 from Japan recently and thought to change all the fluids and oils, so he gave his car to driver and ask him to get all the oils & fluids changed, Driver thought to make some money out of it and poured don't know what in Brake oil bottle and results was devastating, now the LC is stand still in his house, he had done diagnostic test and in result he got these codes and ask me to post here for any proper guidance.
    I request all the experts to please do contribute your experiences and knowledge.Especially @Xulfiqar and @VCheng
    C1201 Engine control system malfunction
    C1203 ECM Communication Circuit Malfunction
    C1252 Brake Booster Pump Motor ONTo
    C1256 Accumulator Low Pressure
    C1336 Zero Point Calibration of Degree
    Note : I am not the owner of this particular Land Cruiser this is a limited information that i got from him by SMS so any further information is hard to get because he doesn't have anything called technical know how
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
    VCheng's Avatar
    May 2010
    Select City
    25,478
    7
    434 Post(s)
    4 Thread(s)
    What fluids were put into exactly where? Was the AHC fluid contaminated too? What fluid was put into the brake system reservoir?
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    Owner said he poured some cheap brake oil in it rest God knows what did he poured into braking system.
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    Rear Brakes are not working and his mechanic said that some sort pressure is not generating. this is the unit which is malfunctioning.
    Reference Pic
    help xulfiqar toyota land cruiser error codes -1311439
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    All these codes point to the ABS control unit and pump going bonkers crazy, It seems that the driver poured the Rs 15/ brake fluid that is usually bought by the old ricksha drivers.
    The obvious first thing to do is to completely powerflush the brake system with proper DOT3 or DOT4 brake fluid, Connect a proper tester to the can system and make the ABS pump work and flush, it might be salvageable, if it does not respond and you are sure the truck was not washed like a buffalo and all wheel sensors are clean and no wiring is broken then the only remedy would be to source a new/salvage ABS pump.
    Test the accumulator pressure sensor - and then proceed logically. It wont be cheap though.
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    you should have advised him to check the sensors first.
    The best car safety device is a rear-view mirror with a cop in it.
    ahmedk06's Avatar
    Jul 2009
    39
    569
    10 Post(s)
    BTW in PK nowadays 90% of brake oil you find at stores is either recycled or counterfeit..try sourcing one from Metro stores or GUARD directly
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Quote Originally Posted by waqar19 View Post
    Indeed, because the codes OP posted are useless. ..
    Sent from my SGH-I747M using PW Forums mobile app
    https://www.facebook.com/OsamaAbbasPhotography
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Take the vehicle to Toyota 3s dealer and make them flush all fluids and change it with correct ones.
    RIP
    epigenius's Avatar
    Apr 2012
    1,085
    33 Post(s)
    Quote Originally Posted by qwertypoiu View Post
    one might as well buy a new car in the price they would quote for an LC 200,but in the end if you can afford a 200 series you can do it aswell
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Quote Originally Posted by epigenius View Post
    not really
    RIP
  12. #12
    epigenius's Avatar
    Apr 2012
    1,085
    33 Post(s)
    not really
    i was being sarcastic in first part of my comment,oh wait ..you commented about latter?
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    In a normal operating vehicle the MC sensor only goes bad when watered brake fluid gets in or something really corrosive happens, As the poster said some weird brake fluid was used and then these faults started to show, it is safe to assume the fluid was really at fault and it may have swelled up the cups and seals which will throw off system pressure. It can and does happen with bad brake fluid.
    However if this would have happened just on a regular day with normal operation then yes - the sensor check would be the first order.
  14. #14
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Brake-eyel brake-eyel hota hai DAT rating ka ho ya SAE rating ka ho
    - if you do not have access to Toyota scan tool i can share a desi Totka to flush the brake fluid from such a car. Some one did it successfully without any damage to a 2004 Land cruiser prado, and am still in shock, because the vehicle is working GOOD without a visit to toyota shop.
    step 1: remove the brake fluid feed to abs pump from boaster fluid reservoir
    step 2: remove all fluid feed lines from abs pump in engine bay
    step 3: remove fluid feed line to wheels
    step 4: apply low pressure air to all 4 lines brake lines will be empty
    step 5: refill fresh brake fluid in reservoir & pump pedal to drain out the fresh & contaminated fluid
    step 6: remove battery negative (ground) from battery terminal
    step 7: reconnect the fluid lines on all wheels
    step 8: reconnect the fluid line to abs pump
    step 9: reconnect wheel feed lines on abs pump
    step 10: fill fresh brake fluid
    step 11: reconnect battery negative (ground) to battery terminal
    step 12: start engine & bleed each wheel one by one 100 ml each wheel shall be discarded to ensure bad fluid is out & away from abs pump
    - to me its crazy - because the only error popped was check brake fluid lamp on dash cluster which also turned off after top-up
    but thats' how Ustaad did it in under 1 hour without any scan tool & wisdom we call Technical skill, at Mir pur mathelo.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    you dont need to disconnect anything just need a person to pump the pedal and about 2 litres of brake fluid, purge from the wheels. However if you are sure the ABS pump has been murdered - then it pays off to undo it, otherwise it makes sure you cry.
    in any case - change fluid every year without forgetting.
    dont you love the "birake haail kabhi nahi change hota jitna purana utnaa acha"
  16. #16
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    can we use a power bleeder in such case?
    Also, how to make sure that the ABS pump is working, without a proper diagnostic system?
  17. #17
    ahmadbila's Avatar
    Aug 2005
    Dubai
    26
    12,963
    5
    95 Post(s)
    11 Thread(s)
    beta cruiser farigh hy ab, 3 lakh mai deni hy tou bat karo. or bhi koe 5-10 hazar ka farak hy tou nikal dain gy
    When the power of love exceeds the love for power, the world will finally know peace=Every man is guilty of all the good he didn't do
  18. #18
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Quote Originally Posted by ahmadbila View Post
    If AHC is screwed then it really is
    RIP
  19. #19
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    When the AHC screws up, its time for a proper offroad suspension and a lift.
  20. #20
    ahmadbila's Avatar
    Aug 2005
    Dubai
    26
    12,963
    5
    95 Post(s)
    11 Thread(s)
    well then looks like im getting an LC soon whats an AHC btw?
