Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By capsat
  • 1 Post By AmeerUsman
  • 1 Post By capsat
Thread: Urgent-ECU connector of 2KD-FTV Hilux Vigo
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Default Urgent-ECU connector of 2KD-FTV Hilux Vigo
    Salaam to all
    Need help regarding ECU output connector. Can anyone share the connection diagram. Actually we need to use speedometer output of 2KD-FTV (official local hilux VIGO model 2011) for some official purpose. Can someone tell the pin # of ECU where speed signal is transmitted/received. Thanx in advance.
    @Xulfiqar @capsat
    please help
    Regards
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,577
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Arrow
    walai kum usalaam please click here got page 61 and here goto page 64 I hope it will help, Guru Xulfiqar & SER_GTR can pin point for a Bulls eye.
    so u are looking to hook up a tracer device with so many inputs to monitor & keep ^check
    Quote Originally Posted by AmeerUsman View Post
    Salaam to all
    @Xulfiqar @capsat
    please help
    Regards
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Quote Originally Posted by capsat View Post
    Thanx sir for a quick reply. Still im reading it but hope to find the desired result.
    If not then will disturb u again
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,577
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Please do share the purpose when accomplished
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Ok boss will try to share but its a national secret. Just to give u a hint...we want to reduce error in GPS.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,577
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    GRRR ........ use speedometer input to connect on NEMA of GPS card / device. Or simply use a 12 /16 channel GPS engine board with external antenna can give you +/- 5 meter error -
    Yellow Garmin Etrax handheld unit stick on dash gives me error of 1/kph at 80 kph & net 4 km error at every 100 km covered.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Thanx brother. We will also think about this suggestion.
