Results 1 to 16 of 16
Like Tree3Likes
  • 2 Post By Xulfiqar
  • 1 Post By Xulfiqar
Thread: Suggestions required regarding Kia Sportrage Engine Swap
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    Default Suggestions required regarding Kia Sportrage Engine Swap
    I need to swap engine of kia sportage , currently its having a toyota 3S with stock gear box, but idk which generation 3S it is. I have searched through many threads on pakwheels and came across that three engines are mainly used Toyota 3S, Mazda F8 and Mazda FE.
    Fuel economy is not an issue but I need good power in the jeep. The current engine is quite noise on high rpms. Suggest some good engine experts.
    I have gone through some 3S engines and found that the 5th generation 3S-GE ( black top ) gives around 207hp & 216Nm torque, can I swap that engine ?
    Best
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    bumppp
    hash4u's Avatar
    May 2005
    38
    24,380
    18
    406 Post(s)
    13 Thread(s)
    13
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    i have gone through whole of this thread, i particularly need suggestion about the 3s-ge fifth generation, and any other engine producing good power..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    1UZ FE - nothing else for sportage
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    are you sure ?
    can you give me some details like which gear box to use, stock or someother one ? price idea of 1uz-fe ? 4000cc would be adjustable for sportage ?
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    anyone?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by sbnshahid View Post
    are you sure ?
    it will bolt on as its not much longer than a 5 cyl engine, it will surely tear up the differential though - it may also twist the chassis rails.. In a nutshell its really overpowered for this little car.
    a regular run off the mill mazda FE will suit it perfectly, If you cannot find one then a Toyota 22R (2.4 cressida/hilux engine) is also very suitable, the 22R is known as "it will not die"
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    what about 5th generation 3S-GE ?
    and regarding toyota 22r, whats the price idea?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    any wide valve angle engine requires you rev the living daylights out of it to make any usable torque - any toyota GE engine is that, the old 22R is like a blacksmith's anvil - it just keeps going on, its a plain oldschool SOHC engine that started as a carburettor engine, Not very revvy, not very advanced but tough as rocks.
    hash4u's Avatar
    May 2005
    38
    24,380
    18
    406 Post(s)
    13 Thread(s)
    13
    3CT would give the ideal power to weight ratio to this
    y petrol only?
  12. #12
    muddy786's Avatar
    Nov 2006
    40
    92
    I totally agree with hash4u.....
    Sent from my GT-N7100 using PW Forums mobile app
  13. #13
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    Quote Originally Posted by hash4u View Post
    y petrol only?
    they are difficult to maintain, so petrol is priority....
  14. #14
    sbnshahid's Avatar
    Apr 2012
    178
    2 Post(s)
    anyone ?
  15. #15
    basitt456's Avatar
    Feb 2015
    Rawalpindi
    64
    2 Post(s)
    Sportage
  16. #16
    basitt456's Avatar
    Feb 2015
    Rawalpindi
    64
    2 Post(s)
    Also suggest any good mechanic in rwp
Tags for this Thread
