Mini Pajero.....with
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 3395 x 1475 x 1595
Interior dimensions (LxWxH), mm 1590 x 1220 x 1210
Wheel base, mm 2280
Treads (F/R), mm 1275 / 1270
Ground clearance, mm 155
Curb vehicle weight, kg 960
Gross vehicle weight, kg
Seating capacity, persons 4
Doors number 3
Min.turning radius, m 4.8
Fuel tank capacity, l 43
ENGINE
Displacement, cc 659
Engine model 4A30T (turbo intercooler)
Max.power (Net), kw(PS)/rpm 64 ps (47.07 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 10.2 kg*m (100.03 N*m) / 3500 rpm
Power density 15
Engine type Serial 4 cylinder DOHC20 valve IC turbo
Engine information
Fuel system ECI multiple (electrically controlled gasoline injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 60
Stroke, mm 58.3
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6.6
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 185/65R15
Tires size rear 185/65r15
Braking system, front Ventilated disk
Braking system, rear Drum (leading/trailing)
Suspension system, front McPherson strut type coil spring
Suspension system, rear 5 link type coil spring
