Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Like Tree4Likes
Thread: Prado 3Door LJ- engine swap 2L-TE to 1KD-FT / 5VZ
    TurboTanga's Avatar
    Jun 2008
    27
    110
    Default Prado 3Door LJ- engine swap 2L-TE to 1KD-FT / 5VZ
    Salam!
    Usually 1KZ is considered a practical option for engine swap in 2L/3L prados. Now we all know that 1KZ with all its positive factors is very fuel thirsty, so
    My question is that is possible to fit a 1KD into 3 door prado?
    How is 5VZ (v6 petrol) for an LJ SX? Can a 2L-TE be replaced with 5VZ?
    How are 1kd and 5vz engines fuel consumption vise?
    Thanks!
    kamran_hayat's Avatar
    May 2014
    Peshawar
    29
    80
    i would suggest 1KZ for lj if you can afford diesel.
    i have swaped 5vz in lj and i am fully satisfied.5vz is more then enough for lj power wise.
    dont have any information about 1kd.
    TurboTanga's Avatar
    Jun 2008
    27
    110
    Thanks kamran!
    I'm inclined towards 5VZ but I'm not sure about the fuel consumption.
    Did you swap it in a swb lj7* ?
    Whats the fuel consumption like?
    Is it a straight conversion or alteration?
    Sent from my GT-I9300 using PW Forums mobile app
    May 2014
    Peshawar
    29
    80
    5vz is a good option and cheap too if compared with others.
    i swaped it in swb 3 door lj70.orignal was 2L engine.
    fuel consumption is 7 and 8 and if you drive roughly it comes down to 5 and 6km/l.
    its not straight conversion you need some modification but thats not that much complex.
    why dont you share your lj pics?
    choctalpur's Avatar
    Feb 2010
    Hyderabad
    142
    Quote Originally Posted by kamran_hayat View Post
    I have a 2Lt in my LWB prado 91, gives me 6.5-8.5 per lit depending upon the shifting and of course, how you paddle the accelerator. That makes 5vz a strong candidate if considered a swap. The fuel consumption is reasonable given the power of the engine(it's a 6 cylinder engine whereas 1kz is 4). It's Petrol.
    You can also consider 1jz 3.0 lit supra engine. It is cheaper than the kz and vz engines, and gives reasonable power the rig. Can't comment on the alteration techniques though. I'm sure it's nothing a qabil mistry can't handle.
    atb. Choc.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    1KD will give good fuel economy, but it is difficult to maintain in Pak due to low quality of diesel. Common rail engines require clean fuel with low sulphur content. Injectors get worn out quickly.
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    1kd is a no
    Injector issue due to sulfur in r diesel n these engines r way expensive !
    1hd would be even better thn 1kd
    Go for 5vz mate it to ur 2lte manual tranny , ull need a custom housing
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    1KD & 2KD are the best choices if you want to stay diesel .
    Fuel average of KD series is way better than 1Kz ones .
    Or you can fit a 5L EFI version as well if want to make life simple .
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    1hz is good option and 5vz... once done they will not give problems for years to come
    RIP
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Quote Originally Posted by joinami View Post
    hmmmmmmmmm
    Imran how difficult or easy 1KD or 2KD is to hook in terms of electronics and wiring, keeping in view the electronic throttle and the immobilizer issues
    1KZ is heavy on fuel but it can perform better than a 5L-E.
    5L-E will deliver a good millage....
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    Quote Originally Posted by qwertypoiu View Post
    1HZ will be an over kill in a TLC LJ
  12. #12
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    Quote Originally Posted by hsumbal1 View Post
    I may be wrong
    But 1hz also comes stock in a rkr hj70 thn why a overkill ?
  13. #13
    TurboTanga's Avatar
    Jun 2008
    27
    110
    Salu bhai there is a huge difference between hj/hzj/bj/fzj and lj/kzj frames. Leafspring ones can take all the heavy engines while the later swbs are considered light duty 4wds.
  14. #14
    TurboTanga's Avatar
    Jun 2008
    27
    110
    Thanks very much guys for the valuable input. Things are going slow with the project due to ramzan.
  15. #15
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Hameed brother it's not difficult to wire the KD series at all .
    Here one can get a complete harness loom as well .
    Most of the 1KD having turbo timers as well and delivering very good average as well .
    Old is Gold
  16. #16
    ahsan17711's Avatar
    Oct 2014
    45
    Dear TurboTanga, any update on your project.
    I also have a Prado 1992 (5 door) with 2.4L engine. Am also planning to replace its engine, can anyone guide.
    Thnx
  17. #17
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Quote Originally Posted by ahsan17711 View Post
    Thnx
    Best option is to put a 1KD-FTV
    or the minimum you can go with a 5L or 1KZ..
    these are the easiest swaps if you want to stay diesel.
    Old is Gold
  18. #18
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    what are the de merits of 2LT?
  19. #19
    ahsan17711's Avatar
    Oct 2014
    45
    To me it's a bit underpowered and engine head crashes due to heatup.
  20. #20
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    my recommendation's are for 1KD-FTV the fuel economy with auto transmission is above 12 on highway's and 8-10 in local's. 5VZ is a little heavier on fuel like 1KZ 5-6 in local and 8-9 max on highway's so go for the 1KD-FTV newer gen engine's easily available and yet easy to wire up and it will be pleasure and fun to drive.
