Results 1 to 3 of 3
Thread: Flashing 4x4 lights in Surf 2004
    syedfarrukhali's Avatar
    Mar 2008
    42
    9
    Default Flashing 4x4 lights in Surf 2004
    I have Toyota Surf 2004. The 4x4 lights in the console, all of them, sometimes start flashing as I start the vehicle and remain flashing throughout. However, after sometime if I shut down the engine and restart it, the problem is no more there. I wonder what is the problem.
    john0995's Avatar
    Jun 2008
    Hari pur
    1,532
    17 Post(s)
    I think some short circuit
    CoMmiNg SoOoOoOoOoOoOoOoOn
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    check the transfer case oil for shavings in it, the wiring that goes to it is above the case and requires removal of the whole gearbox which is a very heavy ordeal.
    The centre diff is engaged by a little motor and two sensors that report back that the diff is engaged.
