Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Like Tree27Likes
Thread: My new ride 1990 - Nissan Patrol / GQ / Y60 Stock TD42 with manual Transmission.
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Default My new ride 1990 - Nissan Patrol / GQ / Y60 Stock TD42 with manual Transmission.
    Friends
    Introducing recent addition of another 4x4 in my garage which is now ready to rock all terrains after doing following jobs
    Replacement of all fluids and all filters.
    Replacement of all servo's, cylinders and brake pads.
    New clutch and pressure plates.
    New suspension replacement using stock parts.
    New Steering system.
    New electrical wiring and now each and every bit is working.
    New on board audio & video entertainment system.
    Installation of all new steel fender flares.
    BFG mud terrain tyres and new alloys.
    All new upholstery including sound deadners and new carpet on floor.
    NP gurus are requested to please suggest appropriate up gradation other than above to make it a true and reliable RV.
    Regards
    Oct 2014 Pics.
    My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489221My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489222My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489223My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489224My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489225My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489226My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489227My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489228My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489229My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489230My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489231My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489232My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489233
    <<<The Obstacle Is The Path>>>
    1984 BJ41, 1967 FJ40, 1984 BJ61 , 1983 Mutt M825, 1982 CJ5, 1942 Willys
  2. #21
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Quote Originally Posted by sherwan_88 View Post
    My suggestions.
    1. Raise it by 2 inches. Get a complete kit, don't go for the desi solution of just mounting bigger springs. They don't correct castor and you will have the death wobble above 80 km/h. Y60 is lowest 4x4 ever. You will have belly down issues.
    2. No matter what the diesel pump "mistree" tells you, do not run it lean. If it is the inline 6 pump and not the rotary. It is imperative. Little bit of black smoke is always better than melting the piston rings.
    3. Stock air filter is useless. Its better to custom mount some type of modern air filter. Increases engine life by half and halves the oil change intervals.
    4. Get a winch, it comes in way handy. It weighs nearly two and half tons and it takes quite a lot of poor little jeep buggers to pull it out.
    5. Snorkel would be a nice addition since the engine runs out "phook" after 3000 rpms.
    6. What ever you do say NO to the "desi pital radiator".
    7. Rear drum brakes have a mind of their own. Keep them clean since it takes a certain amount of braking to stop this bugger.
    8. A good addition would be to add aftermarket, oil pressure, water temp and an egt gauge.
    Hello @sherwan_88 brother - Good to see you active in this section after a long time, i remember your GQ chop and indeed that project was one of those which became inspiration for me to put my hands on a y60
  3. #22
    dogarz's Avatar
    Feb 2011
    41
    1,073
    23 Post(s)
    Congratulations. I am also this close to acquiring a Y60. Your detailed experienced analysis will come in handy. Cheers!!!
    Keep your friends close but your enemies closer...
  4. #23
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Quote Originally Posted by machine View Post
    I hope your not planning to chop yours.
  5. #24
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Not now but who knows
  6. #25
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Last morning I got the opportunity to take detailed pictures of GQ, so i thought to share these with you guys
    My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489208My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489209My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489210My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489211My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489212My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489213My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489214My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489215My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489216My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489217My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489218My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489219My new ride 1990  Nissan Patrol  GQ  Y60 Stock TD42 with manual Transmission -1489220
  7. #26
    qwertypoiu's Avatar
    Feb 2007
    29,136
    153 Post(s)
    3 Thread(s)
    Simply love it, my childhood was mostly the 90's I grew up watching these vehicles and still love them, y60, 80 series, Mercedes w124 and w140... simply adore them till this day..
    Also used to be in Multan and remember some crazy stuff with a Hilux double cab...
    Seeing these pix sent me back in time
    RIP
  8. #27
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    @qwertypoiu - Bro, comeover to Multan someday & we'll take you back in the past
  9. #28
    dogarz's Avatar
    Feb 2011
    41
    1,073
    23 Post(s)
    Love the attention to detail you put in while restoring your rigs. Commendable!
  10. #29
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    @dogarz - Thank you brother. By the way did you buy that y60?
  11. #30
    dogarz's Avatar
    Feb 2011
    41
    1,073
    23 Post(s)
    No Sir. Got busy elsewhere and it slipped away.
  12. #31
    machine's Avatar
    Jul 2009
    Other
    869
    17 Post(s)
    3 Thread(s)
    Help - Please share on your wall or with friends on Pakwheels.
    Unfortunately i have lost this following jeep. Someone has stolen it last night in front of my home. You are requested to please share this on your facebook wall so that if someone from your friends list may have any leads or have seen it somewhere, that can be reported. Its registered in my name from Lahore bearing registration number LOE-1000. FIR has been launched in Multan and the data has also been reported to national anti car lifting cell but there is a possibility that it has gone to upper north or Baluchistan.Your help will be much appreciated.
    Nissan Patrol 5Door
    Registration No. LOE-1000
    Engine Number: TD42-038129
    Chasis No: 107690
    Kamran Zaffar
    0341-666-0000
  13. #32
    dogarz's Avatar
    Feb 2011
    41
    1,073
    23 Post(s)
    Oh God this is terrible news. I pray you get it back.
