Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Demonoid
Thread: Hilux Vigo Smoke Problem
    zaqidwai's Avatar
    Mar 2014
    7
    Default Hilux Vigo Smoke Problem
    Dear Diesel Experts!
    Your help is needed, I have vigo-2006(thailand version)- automatic version, the truck gives thick black smoke on acceleration, heavy blows of smoke on sudden or harder push on accelerator, secondly it also gives small amount of black smoke continuously on AC. Lastly the voice of engine has also changed over last 4 month, I want to minimize the engine though its a diesel engine but i want to keep as less noisy as possible.
    I consulted one mechanic near Garden KArachi, he advised to get the EGR serviced. However, i was advised by my car dealer to get the atomizer services.
    Please advise what could be the root cause of this smoke issue and how it could be solved. Secondly, I am planning to get oil change please advise which oil is better for Vigo.
    If possible please share contact details of good diesel mechanics in KArachi.
    Br,
    ZQ
    Demonoid's Avatar
    Jan 2012
    2,030
    6
    85 Post(s)
    2 Thread(s)
    Get your EGR, Throttle Body & Intercooler serviced... & you are good to go.
    https://www.facebook.com/CAR.Fest.Pak
    zaqidwai's Avatar
    Mar 2014
    7
    Thanks yeah got my EGR serviced , got the air filter and diesel filter also changed and smoke has dropped like 70-80%. Please could you advise how could i improve the sound of engine because there is too much... "Bhurr --Bhurr" is it possible having a silent or low noise diesel engine.
    amnd's Avatar
    Dec 2011
    37
    188
    5 Post(s)
    Quote Originally Posted by zaqidwai View Post
    Has the voice increased over the time or been there since day 1? D
    zaqidwai's Avatar
    Mar 2014
    7
    I bought this truck a few months back....yup over these months the voice have increased
    shaheerali007's Avatar
    Feb 2010
    31
    220
    I have prado 93 with 1kz engine little black smoke what should i do
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    get your vehicle fuel injector's compensation code's entry. The ECU will compensate the fuel according to each cylinder so hence less knock sound and good fuel efficiency as well and smooth acceleration on low range rpm's
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    tough job,
    remove the injectors first. Also check that the fuel pressure regulator valve is the updated part.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    ^^ no sir just remove the intercooler assy and the injector's code's will be clearly visible I had done it several time's on Thi Vigo's and JDM Surf's.
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    tough job,
    yup sir you are right there are many flaw's of PRV are reported by many customer's these day's on old engine's. New one is difficult to find these day's.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by rajaatta View Post
    new one is only ordered from Japan
