Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By msabbasi
  • 1 Post By nawan885
  • 1 Post By amigoamir1
Thread: ABS light problem in prado
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    Default ABS light problem in prado
    dear friends.
    the ABS light of my prado 2003 automatic comes on when i start it. for a few seconds it remains off but again gets on and then stays like this. pl let me know if i can fix it my self or need to go to the mechanic,pl note i am not in my home city right now and dont know any good mechanic in pindi. your early reply and help is required. thanks alot.
    msabbasi's Avatar
    Aug 2013
    55
    1,483
    59 Post(s)
    ABS system does a self check that is why light goes off like normal, then the self check takes place, the check fails and the light comes on permanently. Usually such problems are triggered by a faulty wheel speed sensor or most probably by a faulty/broken sensor wire. If you want to do the job yourself take the car to a service station, get the car on the lifter and get under the car to look at the ABS sensors located at each of the four wheel hubs. Then trace and follow the ABS wire back to the connectors and look for breaks in the wire. If wire continuity checks out then it requires professional attention. Best place is the Toyota 3S place in your city.
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    Quote Originally Posted by amigoamir1 View Post
    dear friends.
    if you are in Rawalpindi you can contact RT's Diagnosis they are expert's in Toyota Diagnosis and Scan Service's they will inspect your vehicle with the Toyota Scan tool and will solve your problem. Their contact is 0311-4451670
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    thank you so much for the reply.the reason i wanted to do it myself was that i dont know any mechanic in pindi,i thought it might be a small issue.anyways your suggestions are quite helpful inn sha allah will try to act upon tomorrow.
    one thing more i noticed today was that 2 out of 5 times the light went off and never came back during the entire drive?
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    Quote Originally Posted by rajaatta View Post
    thanks bro,yes i am in pindi i saw your reply a bit late.will they be opened on sunday?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    TOP up the brake fluid please @amigoamir1
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    Quote Originally Posted by capsat View Post
    fluid level topped up.
    rajaatta's Avatar
    Apr 2014
    680
    12
    25 Post(s)
    yup they are opened on sunday ... please contact them before going there.
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    ok thanks bro,jazak allah.
    nawan885's Avatar
    Jan 2008
    36
    599
    7 Post(s)
    Good... getting this job done by self is also great
    Sent from my GT-I9300 using PW Forums mobile app
    msabbasi's Avatar
    Aug 2013
    55
    1,483
    59 Post(s)
    Perhaps one of the 4 wheel sensor wires is doing a make and break deal?? Anyway good luck with resolving the issue.
  12. #12
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    Quote Originally Posted by msabbasi View Post
    thanks alot bro,you have been a great suport.
  13. #13
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    bro the light issue is resolved by itself for the last one day its no more their and behaving as normal. it was my duty to inform you as you were kind enough to help.thanks once again.jazak allah.
  14. #14
    msabbasi's Avatar
    Aug 2013
    55
    1,483
    59 Post(s)
    Great to hear that the problem is resolved. You are welcome. Thank you for being thoughtful for the update.
  15. #15
    amigoamir1's Avatar
    Nov 2010
    126
    5 Post(s)
    you are welcome bro.
