Results 1 to 4 of 4
Thread: Grinding noise in Potohar when releasing gas pedal
    junaidaftab86's Avatar
    May 2008
    30
    31
    Default Grinding noise in Potohar when releasing gas pedal
    During driving, when i release the gas pedal, there is a grinding noise coming from the transfer case, the transfer case lever wobbles like hell in this situation. This is mostly noticeable on rough roads.
    Last work done was changing the parking brake shoes mounted on the axle.
    hayzin's Avatar
    Jul 2006
    1,626
    87 Post(s)
    2 Thread(s)
    Check your transmission. Most likely the shaft/cross should be checked.
    4x4 for life!
    May 2008
    30
    31
    The rear shaft was slightly out of phase, have corrected it. Lets hope it solved the problem.
    Sent from my iPhone using Tapatalk
    May 2008
    30
    31
    @noman8ff brother plz help, the problem is not solved yet...
    The sound comes at 60kph+ speeds, and if i hold the transfer case stick, the sound is gone..
